B18B1 parts list for a refresh/rebuild
Old May 25, 2004 | 02:08 PM
PHiZ's Avatar
Default B18B1 parts list for a refresh/rebuild
Here is the list I have so far, what else would you reccomend for a refresh/rebuild?
06110-P75-020 GASKET KIT, CYL HD (Clinder head gaskets, IM, EM, head, valve cover, etc.)
06111-PR4-020 GASKET KIT (Lower end gaskets, oil pan, oil pump, etc. etc.)
90013-PR4-A00 BOLT B, HEAD COVER (Center valve cover bolt)
90012-PM7-000 BOLT B, HEAD COVER X4 (Exterior valve cover bolts)
19200-P75-003 Water Pump (Water pump)
14400-P7J-004 BELT (125RU26) (timing belt)
14516-PR4-A00 SPRING (Tensioner spring)
91203-PR4-004 OIL SEAL (27X43X9) X2 (Cam Oil Seal
15100-P72-A01 PUMP ASSY., OIL (Oil pump P72?)
90006-PR3-003 BOLT-WASHER (11X104) X2 (Main Studs)
90007-PR3-003 BOLT-WASHER (11X90) X8 (Main Studs)
94301-08140 PIN, DOWEL (8X14) X3 (Cam holder dowel)
31110-P75-014 BELT, ALTERNATOR (Alternator belt)
13011-PR3-003 RING SET (STD) X4 (Rings, non-overbore)
13014-PR3-S10 WASHER SET, THRUST (Thrust washers)
I need main and connecting rod bearings, but I won't know which color coded ones to get until I check the crank.
Thanks to http://www.acuraparts247.com for all the OEM part numbers.
-PHiZ
Old May 25, 2004 | 04:55 PM
vtecb20coupe's Avatar
B A N N E D
Default Re: B18B1 parts list for a refresh/rebuild (PHiZ)
i take it you're not willing to go with the acl bearings for the mains and rods? there's supposed to be a code on the crank i believe that the dealer is supposed to be able to look up and get your bearing colors. otherwise, if this is the stock b18 from your actual car, just use the vin #.
Old May 25, 2004 | 05:38 PM
PHiZ's Avatar
Default Re: B18B1 parts list for a refresh/rebuild (vtecb20coupe)
It is well documented how to choose appropriate color coded bearings for the mains. that's not my question. If my crank is withing spec, yes I may use ACL bearings or something.
My question is, am I leaving anything out of a refresh/rebuild.
-PHiZ
Old Jun 3, 2004 | 09:13 AM
PHiZ's Avatar
thanks for all the help guys
I forgot head studs.
90006-PR4-A01 BOLT-WASHER (11X188) Long head studs qty 2
90005-PR4-A01 BOLT-WASHER (11X158) Short head studs qty 8
-PHiZ
Fairtax4me
Mar 17, 2014 07:21 PM
TougeCoupe
Nov 19, 2009 03:56 AM
medic4.life
Jul 16, 2007 08:02 PM
PHiZ
Jun 4, 2005 03:15 PM
