will this ecu work?
Old May 25, 2004 | 01:45 PM
wsiracerz's Avatar
Default will this ecu work?
i have a b18b in me eg, its an obd2 motor converted to obd1, all obd1 ecu an dizzy an wire harness an injectors, i have a pr4 ecu, will this work or do i need a obd1 p75?
Old May 25, 2004 | 02:01 PM
PHiZ's Avatar
Default Re: will this ecu work? (wsiracerz)
There are OBD0 and OBD1 PR4. Both of them are designed for the B18(A/B) and will run your car fine.
The OBD0 ecu would require an OBD0 injectors and dizzy (CKP sensor has different number of teeth between OBD0 and OBD1/OBD2)
The OBD1 ecu will run the OBD2 motor (including the OBD2 injectors and OBD2 dizzy) with no problems.
-PHiZ
Old May 25, 2004 | 02:10 PM
wsiracerz's Avatar
Default Re: will this ecu work? (PHiZ)
so even if its an obd0 ecu it will have no effect on how the car runs if its still obd1?
Old May 25, 2004 | 02:21 PM
wsiracerz's Avatar
ok my ques is, if i have obd1 injectors an dizzy an harness, will the obd0 ecu work?
Old May 25, 2004 | 07:05 PM
Kataku2K3's Avatar
Nope, the nonOBD ECU will not fire the OBDI/II dizzy. The nonOBD injectors will work with an OBDI/II ECU (and vise versa) so long as you're running an inline resistor box. Just run an OBDI ECU.
Old May 25, 2004 | 08:41 PM
wsiracerz's Avatar
Default Re: will this ecu work? (Kataku2K3)
yea i wasnt sure if the ecu was the ryt one, but i fixed the prob, it was the iac valve and map sensor on the tb, car runs good, thanks for the info
95 iteg
10
Jun 3, 2013 11:36 AM
Ek9_Cuhzz
Northwest (Sales)
Jul 15, 2010 12:07 PM
Jap_Spec_Imports
Aug 10, 2009 07:11 PM
89hatcher
Apr 5, 2009 06:28 AM
