Overheating Crx ;/
Old May 25, 2004 | 01:35 PM
Skinnypunk's Avatar
Default Overheating Crx ;/
Well on my way to work today i ran my car a little to much i guess(was playing with my new b16a) and when i pulled up to my job site i saw anti freeze leaking.. I popped my hood and the overflow container was boiling/leaking anti freeze. On my way home it started overheating so i got some more anti freeze praying that would fix it but it didnt ;/. While driving on the highway its fine but at traffic lights and such it starts to over heat.
Any ideas?
Old May 25, 2004 | 01:38 PM
civickiller's Avatar
Default Re: Overheating Crx ;/ (Skinnypunk)
i would first do basic things, like i would change the thermostat and put some radiator flush in there and do flushing out the tranny. just to see if that works. if not then when was the last time you changed your water pump ? or your radiator ?
Old May 25, 2004 | 01:41 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Overheating Crx ;/ (civickiller)
Is the electric fan kicking in???
BIG RICH's Avatar
so when your driving its fine, but when stopped it overheats? are your fans kicking on? how is the radiator? hopefully it isn't your water pump, that would suck.
Old May 25, 2004 | 01:48 PM
Skinnypunk's Avatar
Default Re: Overheating Crx ;/ (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Is the electric fan kicking in???</TD></TR></TABLE>
yeah fan is kicking on..
Radiator seems to be fine to my knowledge.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">i would first do basic things, like i would change the thermostat and put some radiator flush in there and do flushing out the tranny. just to see if that works. if not then when was the last time you changed your water pump ? or your radiator ?</TD></TR></TABLE>
As far as I knopw the water pump hasnt been changed in a very long time. Is there a way to test it?
Im going to head out and get some flush as well as a new cap...
Old May 25, 2004 | 02:04 PM
the thermostat is at the end of the lower radiator hose, should be 2 bolts and just put the gasket on the thermostat and put it in, only 1 way it can go
Old May 25, 2004 | 02:08 PM
hahahahhah's Avatar
http://tech.hybridgarage.com/t...l.pdf
PAGE 106
Ryebread1974
Sep 24, 2018 04:24 PM
MFButler
Mar 11, 2010 11:30 AM
dev
Jul 3, 2006 06:54 PM
bigslimdog
Aug 10, 2004 03:37 PM
dbman96
Aug 8, 2001 02:24 PM
