replacing stock pistons with other stock pistons
Old May 25, 2004 | 12:49 PM
ludelvr's Avatar
Default replacing stock pistons with other stock pistons
Just wondering if it's possible to simply pull the head, take off the pan and pull the stock pistons (if the rings are damaged) and then simply replace them with othe stock pistons from a motor that is the same? What has to be done or is it even possible?
Old May 25, 2004 | 01:33 PM
devnull's Avatar
I would use new pistons and rings. And yes it is possible. Though if the rings are damaged the cylinder walls could be scored so you might want to get the block honed to clean it up.
Bgesy
Aug 24, 2006 04:28 AM
kaj
Feb 24, 2006 04:49 PM
Black R
Mar 17, 2005 07:22 PM
BlueSi2k
Feb 27, 2003 11:18 PM
