Water getting in from tailights-- Where can i get the gasket cheap?
Old May 25, 2004 | 11:15 AM
Kimo's Avatar
Default Water getting in from tailights-- Where can i get the gasket cheap?
Hey i figured im not the only one with water getting in my trunk-- i found out its coming in from the tailights-- so im guessing i need a new gasket? the foam piece...
does anybody know where i can get some for a good price? acura wants 31 per side-
also if not the gasket what did you do to fix your leak?? let me know thanks alot
Old May 25, 2004 | 11:41 AM
Kimo's Avatar
Default Re: Water getting in from tailights-- Where can i get the gasket cheap? (Kimo)
bump
Old May 25, 2004 | 11:57 AM
g2typeryellow's Avatar
i just used 3/4 inch weather foam seal. it is that stuff that is sticky on one side and is black foam. it kept the tails from fogin too.
Old May 25, 2004 | 12:12 PM
corona's Avatar
silicone. :thumbup.
Old May 25, 2004 | 05:01 PM
DirtyBirdJR's Avatar
it might not be the foam piece, i might be the seal of the taillight. try sealing the taillight with a clear silicone
Old May 25, 2004 | 05:30 PM
IVI's Avatar
IVI
get some silicone from walmart and seal it all up.
Old May 25, 2004 | 05:40 PM
Kimo's Avatar
Default Re: Water getting in from tailights-- Where can i get the gasket cheap? (IVI)
no water is getting in the trunk no the tailights its coming into the trunk from around the tailights--
yeah i thought about using that tape that is foam on one side-- thanks man
Old May 25, 2004 | 05:49 PM
skunkintegra's Avatar
PM h-t member "ragejed" for taillight gaskets. support your h-t community https://honda-tech.com/zerothread?id=378920
Old May 25, 2004 | 06:43 PM
Padawan's Avatar
Darth ModerVader
Default Re: Water getting in from tailights-- Where can i get the gasket cheap? (skunkintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkintegra &raquo;</TD></TR><TR><TD CLASS="quote">PM h-t member "ragejed" for taillight gaskets. support your h-t community https://honda-tech.com/zerothread?id=378920</TD></TR></TABLE>
Old May 25, 2004 | 06:51 PM
tegracerchick_17's Avatar
I had a pair of tailights that i got off the Internet... they leaked so bad!!! I found that nothing helped, turns out i traded them at a local place for something better.So I know what your going through, but don't have any really good advice!
Old May 26, 2004 | 11:30 AM
Kimo's Avatar
cool
Old May 26, 2004 | 11:57 AM
teggytegteg's Avatar
yo man i had the same problem. the way to do it is go and buy some silicone sticky **** at a auto store and cover up the gap between the body and the tail lights.
Old May 26, 2004 | 05:57 PM
Kimo's Avatar
Default Re: Water getting in from tailights-- Where can i get the gasket cheap? (teggytegteg)
yeah i figured i could do that but im having the whole car painted this month- i dont want to have all that silicone on it u know what im saying? hmm, ill just try different stuff- thanks alot for all the replies
Old May 26, 2004 | 06:48 PM
The Silicone **** didn't work for my car either... Good Luck though
Old May 28, 2004 | 10:05 AM
Kimo's Avatar
Default Re: Water getting in from tailights-- Where can i get the gasket cheap? (tegracerchick_17)
thanks for the info tegracerchick_17 _
ED9man
Apr 28, 2007 11:47 PM
Coupe-R
12
Jul 9, 2006 12:51 AM
triple
Apr 20, 2006 08:22 PM
Fink2iCe
Aug 29, 2004 11:03 AM
crewjones
Feb 15, 2004 02:32 PM
