next mod?
Old Nov 8, 2001 | 08:03 PM
mr2's Avatar
mr2
Default next mod?
stock 94 honda civic cx with a b18c.. what should my next mods be?
im thinking..:
lowering springs/coilovers (suggest a brand plz)
upgraded brakes (SI? GSR?)
cfi hood (fiberimages)
2000 LS rims
nitto dr's
cam gears (suggest a brand plz)
pulleys (suggest a brand plz)
ITR stock header
small stuff
itr shift ****/boot
spoon gauges/si gauges
short shifter (suggest a brand plz)
sway bars
strut bar
intake (suggest a brand plz)
exhaust (suggest a brand plz)
thanks in advance!
Old Nov 9, 2001 | 01:25 AM
mr2's Avatar
mr2
Default Re: next mod? (white eg)
ttt
Old Nov 9, 2001 | 05:49 AM
FSTASNTZ's Avatar
Coilovers, TEIN.
Spring and shock combo, Ground Control/Skunk 2 and Koni Yellow
Brakes, if you want to run a 14" or smaler rim, then the GS-R is about the best you can do, or any performance variation of the same size...
Cam Gears, TODA or AEM
Pulleys, AEM
Header, JDM ITR
Jason
Old Nov 9, 2001 | 09:31 AM
mr2's Avatar
mr2
Default Re: next mod? (FSTASNTZ)
thankz anyone else with their opinion?
Old Nov 9, 2001 | 09:59 AM
976's Avatar
976
New User
Intake - AEM - of course!
Cam gears - TODA, AEM, or Unorthdox
Struts - Koni
Rims - Spoon, or replica that is light weight
Tires - Toyo, Dunlop, Kumho
Header - DC Sports, Mugen $$$
Upgrade fluids and give her (your car) a tune-up!
Spark plugs - NGK
"" Wires - NGK, Magnecor
Dis. cap & rotor - honda
Change PC valve, EGR, etc...
Old Nov 9, 2001 | 12:07 PM
mr2's Avatar
mr2
Default Re: next mod? (B21A)
spoon rims are expensive.. im just going to get the ls rims.. they are nice!
Old Nov 9, 2001 | 01:24 PM
mr2's Avatar
mr2
http://members.tripod.com/dnafenix/aht/gsr.jpg
Old Nov 10, 2001 | 08:08 PM
mr2's Avatar
mr2
ttt
Old Nov 11, 2001 | 04:04 PM
redsin95's Avatar
New User
i would work you suspension, car will be a lot funner to drive if you can hang in the corners.
ground control coil overs, komi adjustables.
benen, front & rear strut bars, benen front and rear tie bars
suspenson techniques rear sway bar, or itr rear sway bar with beaks mounting kit,
polurithane bushing full kit, at least a front sway bar bushing if you run a rear sway bar, nuespeed also has a bushing just for the front bar.
get some good tires, and probably a camber kit.
then if you have any money left over. go for i/h/e to start with. once you have that done you can start to do some cosmetic stuff if you like,
spoon chin spoiler, spoon duckbill, vision mirrors, jdm corners(to bad you can't get the all ambers anymore) carbon hood.
it all depends on what you like and what you wanna do. i gave you alist of things that i woudl do in that order.
Old Nov 11, 2001 | 04:06 PM
redsin95's Avatar
New User
i did not notice that you have a cx i would definatly upgrade your braking system when you do your suspension. if you start adding more power it will wear out your breaks faster and they will not stop you as fast as they should.
Old Nov 11, 2001 | 04:07 PM
Erik_Pb_Foot's Avatar
New User
great suggestions.. i agree with everything... but if you want some inexpensive lightweight rims, what about the rota's? they are light spoon knock-offs.
Old Nov 11, 2001 | 05:32 PM
mr2's Avatar
mr2
Default Re: next mod? (Pb_Foot)
wheres a webpage i can get rotas
Old Nov 11, 2001 | 06:36 PM
New User
check out http://www.seriousauto.com
It's a Miata page, but they are the cheapest I've seen so far
The 15" weighs 12 lbs I think
Good luck
Old Nov 11, 2001 | 06:40 PM
New User
here ya go... thought i'd save you some trouble...
http://www.seriousauto.com/wheels-ti...it8/index.html
Old Nov 11, 2001 | 07:02 PM
mr2's Avatar
mr2
thanks!
patdemps
Nov 11, 2003 07:30 PM
Racer
Mar 17, 2002 03:58 PM
B2FiNiTY
Dec 7, 2001 06:50 PM
6SPD_EK
Sep 20, 2001 12:12 PM
