What's up with the two methods of doing the axles?
Which method is the better: the Repair Manual route of taking the damper fork and LCA off, or the method in the archives: ... "Unbolt the lower control arm from the chassis and the lower shock mount/fork & radius rod and the whole knuckle swings right out of the way Sometimes you do have to remove the sway bar endlink, but usually I can do without. Sound like more work, but it really is quicker IMO. Guy at a honda dealer showed/told me that."
About the only thing I learned is not to use a pickle fork but a pitman arm puller instead. Btw, if I should go the pitman puller route, should I get the smaller Pitman Pullers? You do know there are two sizes, right?
Modified by diyer at 8:11 PM 5/19/2005
uncleben
Nov 6, 2002 05:33 AM
