obd0 ecu code?
have a crx lsvtec recently put another crank...and pistons now its showing cel 24 i think two long beeps four short beeps..does anyone know any obd0 warning codes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soquickls »</TD></TR><TR><TD CLASS="quote">have a crx lsvtec recently put another crank...and pistons now its showing cel 24 i think two long beeps four short beeps..does anyone know any obd0 warning codes?</TD></TR></TABLE>
code 24... hummm got me there, but then again, i've never heard a Honda ECU beep either
Honda Codes:
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
Honda Codes:
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bishop4G »</TD></TR><TR><TD CLASS="quote">Are these codes to any ecu OBD0 and above?</TD></TR></TABLE>
The codes I posted will work with obd0-obd1. obd2 is a different thing all together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">the other LONG list is for obd2</TD></TR></TABLE>
If you are referring to my list, that is for obd0 and obd1, the list for obd2 is about 8-9 pages long. I'm not a fan of obd2 when it comes to mods, but it is NICE when it comes to figuring out whats wrong with your engine/trans.
civicracer94
Dec 8, 2006 06:22 PM
