CEL stays on
Old May 25, 2004 | 09:12 AM
Griffin@Camtech's Avatar
Default CEL stays on
hey guys for some reason my CEL stays on. I do the reset procedure and it never goes away. I also can't pull DTC from it. it never goes out. if the key is on the cel is on. any ideas? its a 92 eg with a p28 ecu. The motor is a 94 ls/vtec.
Thanks
Old May 25, 2004 | 09:34 AM
deSigi's Avatar
When you jump the pin, be carefull not to insert the pin where the plastic tabs are. I had put my paper clip in there and I wasn't able to get the codes.
If you're check engine light is on, then you must have some sort of code.
Cincinnati4g
Jun 7, 2014 01:25 PM
dapek
Dec 1, 2008 09:38 PM
skUnK2jdm
26
Feb 7, 2008 10:08 AM
Griffin@Camtech
May 25, 2004 08:54 AM
flatline
May 20, 2003 10:58 PM
