h22 and h23 cam caps / holders...the same?
Old May 25, 2004 | 08:11 AM
thehondaguru's Avatar
Default h22 and h23 cam caps / holders...the same?
well are they. I really need to know!
Old May 25, 2004 | 08:30 AM
Sam1am26's Avatar
Default Re: h22 and h23 cam caps / holders...the same? (95 lude)
did you break a cam cap?
Well no they are not the same... Even though the cam cap bore it probably not identical anyways, the cam cap design is completely different...
Old May 25, 2004 | 08:31 AM
AndyD's Avatar
You might want to IM Kteller. He had a cam cap issue with the H22 head he bought.
Old May 25, 2004 | 08:32 AM
AndyD's Avatar
Default Re: h22 and h23 cam caps / holders...the same? (Sam1am26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote"> Even though the cam cap bore it probably not identical anyways, the cam cap design is completely different...</TD></TR></TABLE>
I was told that this is the reason why Honda doesn't sell the cam caps separately.
Old May 25, 2004 | 08:49 AM
Default Re: h22 and h23 cam caps / holders...the same? (AndyD)
well I lost them for my h22 head and justwanted toknowif I couldswapthem from my h23 head but Iguess not.
I used different cam caps from a different h22 head on this swap and they seemed to work fine. I cant see why honda doesnt sell them separatly
Old May 25, 2004 | 08:58 AM
Sam1am26's Avatar
The reason Honda doesn't sell them individually is because they are all line bored with the cylinder head to make sure that every cylinder head has cam caps that fit it perfect... Honda builds there motors on such tight clearances though that most of the time the cam caps should all come out the same, however they still won't sell them individually...
Old May 25, 2004 | 09:09 AM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">The reason Honda doesn't sell them individually is because they are all line bored with the cylinder head to make sure that every cylinder head has cam caps that fit it perfect... Honda builds there motors on such tight clearances though that most of the time the cam caps should all come out the same, however they still won't sell them individually...</TD></TR></TABLE>
yes and like someone said, the h23 ones are way different
Old May 25, 2004 | 02:16 PM
Default Re: h22 and h23 cam caps / holders...the same? (Eddiebx)
wow Iam damn glad that all lined up good on mine!
Old Jan 6, 2013 | 10:43 PM
XarupS's Avatar
Do you still have these caps? I'm wondering if I could buy it. Had a broken cap here with my h23 non-vtec header as well.
Your header is non-vtec right?
Old Jan 11, 2013 | 01:34 PM
rowe4166's Avatar
you might want to look at the post date before you bring a thread back like this. Its from 2004
Old Jan 11, 2013 | 01:51 PM
XarupS's Avatar
Well, maybe he hasn't sold it anywhere and stored it on the basement or something for all this years. ahahaha
Anyway, thanks.
Ransom
Mar 15, 2008 08:54 PM
fracas
Mar 17, 2006 06:30 AM
Sam1am26
Apr 22, 2004 02:54 PM
