Tires Rubbing.....HELP!
Old May 25, 2004 | 08:00 AM
Double_Dk's Avatar
Default Tires Rubbing.....HELP!
Hey all...
I just got everything back on my car, took it for an alignment and fix the camber. All ready to rock, right?
WRONG !
I get rubbing on the front pass side when I turn left and hit a bump, and the odd time in any other condition... I got sprint springs on the car and all was good......
Any clue anyone????
Old May 25, 2004 | 08:05 AM
pinkhonda
Guest
Posts: n/a
Default Re: Tires Rubbing.....HELP! (Double_Dk)
If you got Coilovers then you might want to double check both sides are even if so, then maybe you should raise it alittle.
If not try removing the inner lining around the wheelwell - (?spelling)
Old May 25, 2004 | 08:11 AM
spoolineh2's Avatar
Default Re: Tires Rubbing.....HELP! (pinkhonda)
this is quite common, you should just raise the coil overs.
Old May 25, 2004 | 08:28 AM
Andres-eh2's Avatar
what size tires you running?
Old May 25, 2004 | 08:36 AM
Double_Dk's Avatar
I am using lowering springs, so coil overs adjustment is out of the question. I got 16'd on there right now
Old May 27, 2004 | 12:25 PM
pinkhonda
Guest
Posts: n/a
Remove the lining around the wheel well homey. (you can do it!)
Old May 27, 2004 | 01:09 PM
EG2on14inBRWS's Avatar
how big are your rims? try to take out the linner if not they you can roll your fender.
Old May 27, 2004 | 01:45 PM
Daniel_san's Avatar
Default Re: Tires Rubbing.....HELP! (EG2on14inBRWS)
they didn't align it right. go back and tell them to redo it right.
he probably did it according to Stock specs
Solidis
Feb 16, 2014 08:18 AM
philkehn
26
Aug 30, 2006 08:58 PM
lilmoney145
Mar 30, 2005 05:32 AM
spiceisler
Apr 1, 2003 01:03 PM
neutron91
Oct 20, 2002 03:58 PM
