fuel pressure or starter?help!
Old May 25, 2004 | 07:52 AM
sh-ef's Avatar
Default fuel pressure or starter?help!
ok... when i go to start her up it dosen't turn over right away but in like 3 sec. i just recently put a fpr,fuel rail, and fuel filter could it be that or bad starter. car only has 43k on it, anybody have any input?
Old May 25, 2004 | 12:37 PM
hOndafienD 04's Avatar
if it was a fuel problem it would atleast crank......so its a starting problem...check your pattery voltage...if its less then 9.6 volts den it wont crank...
Old May 25, 2004 | 01:53 PM
Speedra500's Avatar
Default Re: (hOndafienD 04)
turn your key to ignition and the turn it off and repeat the process 2 or 3 times and then try starting the car, that will get all the fuel up there, it sounds like a fuel problem to me, what kind of FPR are you using?
Old May 26, 2004 | 07:01 AM
sh-ef's Avatar
Default Re: (Speedra500)
all the fuel parts are aem
Old May 26, 2004 | 08:19 PM
Jago's Avatar
Default Re: (sh-ef)
it's absolutly not a fuel problem
Old May 30, 2004 | 03:22 PM
sh-ef's Avatar
Default Re: (Jago)
if not fuel, the starter is bad?
Old May 30, 2004 | 05:48 PM
check the battery, and if you don't know how to do that, just buy a new 1, or get someone to do it.....could also be something with the starter, take it to a professional.....thats my advice....
caspersrevenge1
Sep 6, 2013 05:02 PM
spore691
Nov 3, 2012 08:44 AM
fallingxlove
15
May 31, 2009 12:19 PM
