CEL stays on????
Old May 25, 2004 | 06:49 AM
Griffin@Camtech's Avatar
Default CEL stays on????
hey guys for some reason my CEL stays on. I do the reset procedure and it never goes away. I also can't pull DTC from it it never goes out. if the key is on the cel is on. any ideas?
Thanks
Old May 25, 2004 | 07:26 AM
JimBlake's Avatar
Default Re: CEL stays on???? (Stickdeath)
What's preventing you from pulling a code? What model/year/engine do you have?
Old May 25, 2004 | 07:45 AM
Default Re: CEL stays on???? (JimBlake)
I jump the 2p conector and the CEL stays lit. it doesn't flash a code of any kind. the chassis is a 92 eg hatch the motor is a 94 ls/vtec the ECU is a obd1 p28
Thanks
Old May 25, 2004 | 08:54 AM
JimBlake's Avatar
Since it's a swap... Are you sure the 2p connector is hooked up to the right place? From my '95, the brown/white wire is supposed to go to D4 of the ECU. The other wire is ground. So I suppose you could simply go to the ECU & jumper D4 to ground. But first, you might want to check whether a '94 P28 uses the same terminal.
shermanyang
Jun 16, 2014 08:22 AM
1sikhatch
Jan 31, 2010 09:06 AM
boostd ls
Oct 4, 2009 09:45 AM
UNKNOWN_MEMBER
Jun 9, 2005 08:09 AM
Griffin@Camtech
May 25, 2004 09:34 AM
