help me fast...about back struts bolts honda accord 97...
Old May 25, 2004 | 05:39 AM
icet's Avatar
Default help me fast...about back struts bolts honda accord 97...
what is the easiest way to get those bolts off honda accord 97...?
i just got done with the fronts but the back one gave me so much trouble...
i even try to cut out the metal piece on the struts itself that hold the bolt but still won't come off...
thanks for the advice....
Old May 25, 2004 | 07:28 AM
EX-JAY's Avatar
Default Re: help me fast...about back struts bolts honda accord 97... (icet)
Good luck with the rears. I had to cut the bolt and destroy the bushing. A lot of people had to do the same. I even used air tools but it did not help. You can try and soak the bolt with penetrating lubricant overnight and apply heat when trying to take them out.
I guess what happens is that the bolt seizes inside the bushing, hence the reason one has to also remove/destroy the bushing. The bushing costs like $20 and the bolt is like $8. Good luck.
Old May 25, 2004 | 09:18 AM
tommymoose's Avatar
Default Re: help me fast...about back struts bolts honda accord 97... (EX-JAY)
I soaked mine with penetrating spray and let it sit for about 10 minutes. Then slip a pipe on the end of your socket wrench or wrech (whatever your using) for extra leverage. Have your lever be at least a foot and a half long and it helps you get a lot more powering into it. The longer it is, the easier it will be for you to break the bolt free.
Old May 25, 2004 | 10:12 AM
one clean ride's Avatar
Default Re: help me fast...about back struts bolts honda accord 97... (tommymoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose &raquo;</TD></TR><TR><TD CLASS="quote">I soaked mine with penetrating spray and let it sit for about 10 minutes. Then slip a pipe on the end of your socket wrench or wrech (whatever your using) for extra leverage. Have your lever be at least a foot and a half long and it helps you get a lot more powering into it. The longer it is, the easier it will be for you to break the bolt free.</TD></TR></TABLE>
We took it to a local mechanic that had access to a car lift. You need a lot of leverage to get the bolt loose....leverage you can't get from laying on the ground.
Old May 25, 2004 | 10:37 AM
KFL's Avatar
KFL
The bolts can be a real bother at times. Basically the bolt will be seized into the bushing. Best bet is to take it to a shop have them torch it out and buy a new bolt if you have to, Usually the bolt has a small coating, sometimes water will get in there and seize it with some rust. .Put a little antiseize on the new bolt. If your going to keep on getting it yourself eventually the bolt will snap in the bushing makes everything a mess. I had the same issue recently on tc rod bolt for my 240sx I used a press to get it out. Should be 20-30bucks I figure for them to torch it out and you'll be okay.
Old May 25, 2004 | 11:42 AM
iam7head's Avatar
Default Re: (KFL)
it's been offically dubbed the name bitch bolt
Old May 25, 2004 | 05:34 PM
hondaguy6513's Avatar
Default Re: (iam7head)
If you are just putting springs on and want to be cheap, you can seperate the upper ball joint and remove the brake line from its hanger on the trailing arm and drop the rear suspension down about a foot and change the spring with the strut on the car.
Old May 26, 2004 | 06:41 AM
icet's Avatar
thanks guys...
i finally gave up...after 3 weeks cursing and struggling with the rotor and tein coilover...
i went to the shop...even them they have a hard time taking those bolt out....
so they have to torch and replace the brushing...there is no way in hell i can do that at home....oh...for honda accord 97 se rotor...those son of bitches tough too...the guy sweat when he tried to take those off...and the rotor need to be pressed....too
so....2 new rotor and 2 back coilover installation...took them 4 hrs...they charged me $365 ....is that a good deal?
icet
Old May 26, 2004 | 12:41 PM
fluxion's Avatar
amin n'rangwa edanea
Default Re: help me fast...about back struts bolts honda accord 97... (one clean ride)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one clean ride &raquo;</TD></TR><TR><TD CLASS="quote">
We took it to a local mechanic that had access to a car lift. You need a lot of leverage to get the bolt loose....leverage you can't get from laying on the ground.</TD></TR></TABLE>
i did the same thing. 5 minute job. they didnt even charge me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icet &raquo;</TD></TR><TR><TD CLASS="quote">2 new rotor and 2 back coilover installation...took them 4 hrs...they charged me $365 ....is that a good deal?</TD></TR></TABLE>
including the cost of the rotors? seems about right. still pricey, but I wouldnt say you got ripped off or anything
fastshift
Dec 7, 2019 06:34 PM
solfire
Apr 4, 2014 06:23 AM
igorka_91
Feb 13, 2010 11:05 AM
96civic909
Feb 15, 2009 05:58 PM
IAcivicEK
Jul 1, 2007 07:37 PM
