possible to recognize a typre r crank?
Old May 24, 2004 | 10:59 PM
blacksi_r's Avatar
Default possible to recognize a type r crank?
i have a crx with a b16a and have just recived a type r dissasembled short block but it had everything but the crank and he says he will get it for me so when i get it i want to be able to tell if it is a type r crankshaft. is there any way to tell a number or mark or mabe the size i could measure it with that gauge i forgot the name of it? anyway i need to know because he has a lot of motors around and i want the right one, thanx
ps also if he cant find one can i use a ls crank is it the ssame thing as far as size, and weight, strength, balence?
Old May 26, 2004 | 12:24 PM
blacksi_r's Avatar
Default Re: possible to recognize a type r crank? (blacksi_r)
bump
Old May 27, 2004 | 11:37 AM
SOUNDEFFECTS's Avatar
Type R crank has bigger, heavier counter weights on the crank. Look for any markings on the crank and post up what it has on it. I think it MIGHT be labeled P73 or it might not.
LS crank will work but its different stroke and requires different rods because of that.
Old May 27, 2004 | 01:27 PM
_BEN_'s Avatar
There is a comparison tread somewhere around here let me see if I can find it.
Edit: here it is https://honda-tech.com/zerothread?id=770989
Old May 27, 2004 | 03:01 PM
Rocket's Avatar
Default Re: possible to recognize a type r crank? (_BEN_)
There's an "R" stamped on the forging.
Old May 27, 2004 | 05:43 PM
dfoxengr's Avatar
we should have a crank weights thread. because theres definitely a difference there.
kent876
Honda S2000
May 9, 2010 10:17 PM
ls-vtec_da13
Jul 22, 2008 07:25 PM
zacatkings
Feb 11, 2008 08:50 PM
b17integra
Jun 13, 2004 02:05 PM
