positve camber in the rear after rear disc swap?
Old May 24, 2004 | 10:53 PM
dng's Avatar
dng
Default positve camber in the rear after rear disc swap?
i put in integra gsr brakes in my 92 civic and notice that the wheel tilts out at the top (rear wheels). i swapped over the trailing arm and all other arms connected. anyone else experience the same thing?
Old May 24, 2004 | 11:02 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: positve camber in the rear after rear disc swap? (dng)
yeah same thing happened to me except my toe adjustment was off. one trip to the alignment shop fixed it
Old May 25, 2004 | 06:49 AM
kommon_sense's Avatar
You should have only swapped the trailling arm. You should have kept all of your other arms (lca, uca, compensator arm).
Old May 25, 2004 | 07:29 AM
suspendedHatch's Avatar
Default Re: positve camber in the rear after rear disc swap? (kommon_sense)
No... you want the LCA. It has the swaybar mounts. I swapped the whole thing and I didn't have a camber problem.
Alignment wont help since camber isn't adjustable.
Are your springs settled? If you have it parked with the ebrake and jack the car up and drop it down it will do that.
It's equal on both sides? Are the parts bent? Was the source car wrecked? A camber kit will allow you to adjust the camber positive and negative.
drsab2000
12
Oct 31, 2013 09:39 AM
r_arraz
Suspension & Brakes
Nov 28, 2012 12:40 PM
wannaBjdmca6
Suspension & Brakes
26
Jan 16, 2011 08:24 PM
beana
Jan 4, 2010 02:08 PM
StolenTeg
Jul 2, 2006 11:26 PM
