Need Help with buying lowering springs!?
Old May 24, 2004 | 06:05 PM
SiCrxer's Avatar
Default Need Help with buying lowering springs!?
Hey guys, new around here i have a 91 Si Crx but anyway on to my question im looking for some cheap budget springs for now and i came across these,
DROPZONE springs are true performance lowering springs, not just a shorter stock spring. They are designed the way performance springs should be, with the correct spring rate and ride height for each specific application. DROPZONE springs provide aggressive drivers with substantially stiffer spring rates and some of the lowest fitments available for street cars. DROPZONE springs lower vehicles 2.0" - 2.5", according to vehicle specifications, providing race car looks with handling to match. All DROPZONE kits are made with the same quality material and design standards used with our lowering sport springs kits. DROPZONE lowering springs are designed to be used with aftermarket sport shock absorbers. Minor modifications or camber kits may be required. All DROPZONE springs carry a ISO 9001 standardization and are TUV approved.
Specifications:
2.5" front/ 2.25" rear (Sold as a set of 4)
Anyway case in point would i need a camber kit or aftermarket sport shock absorbers? Or would they just fit right in? BTW i have a friend who will install the springs for free
Old May 24, 2004 | 06:10 PM
Full Race A6's Avatar
Default Re: Need Help with buying lowering springs!? (SiCrxer)
You would have camber, I dont think it would be more than 2 degrees out though, you would see a difference in tire wear, but kits are pretty expensive
Old May 24, 2004 | 06:28 PM
SiCrxer's Avatar
Default Re: Need Help with buying lowering springs!? (W O T)
So i would need a camber?
also i found these which look the same and are the same price
http://www.shophyperformance.com/store/000993.html
Old May 24, 2004 | 07:32 PM
SiCrxer's Avatar
Bump
Old May 24, 2004 | 08:06 PM
DJ_SaNdOz's Avatar
I would suggest getting a differnt set of springs. I like Neuspeed, but H&R are supposed to be really nice as well. Springs are already cheap, so why go even cheaper?
Old May 24, 2004 | 08:13 PM
SiCrxer's Avatar
Default Re: Need Help with buying lowering springs!? (DJ_SaNdOz)
Well, i only got that money for now and i'll upgrade later. anyway that 2nd link will those springs work ? or will i need extra crap like camber kit and shocks cause i cant buy those right now thats why im asking.
Old May 24, 2004 | 08:46 PM
Why not do it right the first time and asve til you can afford your desired setup?
Stock wont be that bad for 1 extra month
MugenEg
Suspension & Brakes
Feb 7, 2011 08:55 PM
power11
May 15, 2007 11:02 PM
prostreetonline
16
Aug 11, 2005 05:54 PM
92CivicLSI
17
Nov 11, 2004 02:04 PM
