Cylinder 3 dead..
Old May 24, 2004 | 05:02 PM
hahahahhah's Avatar
Default Cylinder 3 dead..
Ok, so I'm coming in from out of town the other night, and as I start gearing down to the local speed limit, I realize that my car sounds like a frigin lawnmower. I could immediately tell that one of my pistons was out, so I pulled over and checked the wires, made sure nothing came loose. Everything was in its place, and so there wasn't much else I could really do right there.
Took my car today and decided I would change the most basic ignition components (dist cap, rotor, wires, plugs). That didn't help, so I did a compression test and came to the conclusion that all cylinders are firing except cylinder 3 had no compression at all. I need some advice on what this could be. I'm thinking that a valve/the valves on cylinder 3 are just messed up.. maybe even the rings..?
Any ideas anyone?
Thanks,
-edmCRX
Old May 24, 2004 | 05:54 PM
deftones0817's Avatar
Default Re: Cylinder 3 dead.. (edmCRX)
try switching injectors and see if another cylinder dies. If so that is your problem. That is what was wrong with my car a while ago.
DEF
Old May 24, 2004 | 06:20 PM
hahahahhah's Avatar
Default Re: Cylinder 3 dead.. (deftones0817)
Sounds good, I'll keep you posted
Old May 24, 2004 | 06:42 PM
blah13's Avatar
If you had no compression in cyl 3 then switching injectors isnt going to do squat. You need to find out why theres no compression. Check for oil in coolant and vice versa, check your valve specs with feeler gauges, and also remove the little "breather" hose that goes from your valve cover to your intake tube and run the car, if theres an assload of smoke that comes from this hose after a minute or 2 from running then its probably rings, smoke is from blowby. If theres a little haze or light smoke then thats normal oil vapors.
Old May 24, 2004 | 07:06 PM
shaddr3's Avatar
Default Re: Cylinder 3 dead.. (blah13)
Hey this is from AF, maybe this will help ya out man. http://www.automotiveforums.co...31027
Old May 24, 2004 | 07:31 PM
hahahahhah's Avatar
Default Re: Cylinder 3 dead.. (shaddr3)
Thanks for the help guys. The compression tester I was using today was pretty hurting, so I'm gonna go pickup a new one tomorrow. Gonna re-check the compression and if there is 0 compression in cylinder No.3 (I'm pretty sure there was) then I'll remove the head I guess and take a look and see whatsup. What compression numbers should my D16 be throwing?
Thanks again,
-edmCRX
Old May 25, 2004 | 02:16 PM
hahahahhah's Avatar
Ok, got a proper compression tester today, tested all my cylinders, and these are the readings I got.
Cylinder 1 - 190
Cylinder 2 - 183
Cylinder 3 - 0
Cylinder 4 - 184
Makes no sense. I removed the vaccuum line going from the vavle cover breather to the intake and there was no smoke at all.. so I'm assuming that it's something in my vavle-train . Guess I'm just gonna have to take a look for myself
-edmCRX
Modified by edmCRX at 4:46 PM 5/25/2004
Old May 25, 2004 | 03:23 PM
Donkey85's Avatar
it is not uncommon for honda motors to have their 3rd cyl to go out. double check your valves to see if one isnt cracked or even half of it missing
Old May 25, 2004 | 05:09 PM
hahahahhah's Avatar
Default Re: Cylinder 3 dead.. (Donkey85)
Yea I guess I'll just have to do that. How hard is it to replace a valve? If I replace one, should I just replace all of them at the same time?
Thanks for the replies.
-edmCRX
Old May 25, 2004 | 06:42 PM
ham's Avatar
ham
these people are making things too complicated for you. just put the cylinder at TDC on compression stroke and hook up shop air to the compression checker (take the gauge off) and see where there is air coming out. Where it comes out is what is broken.
ex. if air is going out the exhaust... an exhaust valve is bad.
Old May 25, 2004 | 06:47 PM
hahahahhah's Avatar
Default Re: Cylinder 3 dead.. (zcnos)
ahhh I see.. k well I'll give that a go tomorrow
Old May 25, 2004 | 06:52 PM
mr_valentino20032000's Avatar
ok i have the smae question how hard is it to replace a valve? what tool do i need etc....thanks good luck on your car man
turboD_EG
Apr 17, 2009 07:19 AM
Tyteg
May 16, 2007 07:30 AM
Sonik_fury
Sep 7, 2006 10:41 AM
mikester_91
Mar 12, 2005 02:35 PM
LSVTEC 91 Civic
25
Jul 12, 2004 01:49 AM
