A/C Squeek
Old May 24, 2004 | 04:48 PM
Ricey McRicerton's Avatar
Default A/C Squeek
Okay, summer is here and so is the use of the A/C.
Now when I turn the A/C on at a stop, there is an intermittent squeak. It's not a constant squeak, so I don't feel that it is a belt, but rather a squeek, half second to 2 second pause and then another squeek.
Any ideas as to what it can be?
Old May 24, 2004 | 05:08 PM
EL Vap133's Avatar
Default Re: A/C Squeek (Ricey McRicerton)
Maybe something lose around the compressor?
Old May 24, 2004 | 05:10 PM
Default Re: A/C Squeek (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe something lose around the compressor? </TD></TR></TABLE>
Almost sounds like it's coming from there...I'm kinda thinking the clutch may be giving up....
Old May 24, 2004 | 05:12 PM
articbluedc5's Avatar
Mine started doing that, then the clutch died completly
Old May 24, 2004 | 05:18 PM
ej1 pilot's Avatar
i would guess something to do with the alternator
are you sure the belt is not loose?
my friends screeched whenever he turned on the a/c, lights, or sometimes even radio, and it was just a loose alt belt
check it out
EDIT- reread whole post, my friend i mentioned above did not have a constant screech either it was 5-10 seconds depending on how long it had been since the car was on so definitely tighten up your belt and see if it stops
Old May 24, 2004 | 05:21 PM
Default Re: A/C Squeek (Sl0wEH2)
It's just when I turn the A/C on. Kinda sounds like my compressor is on the way out....
Old May 24, 2004 | 05:32 PM
ej1 pilot's Avatar
just get rid of your whole a/c unit weight reduction
Old May 24, 2004 | 05:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sl0wEH2 &raquo;</TD></TR><TR><TD CLASS="quote">just get rid of your whole a/c unit weight reduction </TD></TR></TABLE>
No damn way. Its hot here and I have to wear long pants/a collared shirt to work. After work I have got to use the A/C or I'll melt into a puddle.
Old May 24, 2004 | 05:48 PM
bushfreakz's Avatar
my ac does it everyhting i rev high or turn it on while driving.. it goes psshhh.. like a blowoff sound... ac works ok. but its a compressor and has a release right?
Old May 24, 2004 | 05:53 PM
ej1 pilot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
No damn way. Its hot here and I have to wear long pants/a collared shirt to work. After work I have got to use the A/C or I'll melt into a puddle. </TD></TR></TABLE>
me too, and i work 6 days a week, i was jk i would die without a/c!
Old May 24, 2004 | 06:10 PM
Emong3's Avatar
Seems the clutch is slipping. There must be something wrong with the clutch or yuor compressor is starting to sieze.
Another problem maybe that receiver dryer might be clogged which causes liquid refrigerant to enter the suction of the compressor, which causes the compressor to work harder since liquid is basically hard to compress.
Old May 24, 2004 | 06:16 PM
hayabusa160's Avatar
Default Re: A/C Squeek (Emong3)
crap mines starting to do that and it takes awhile to produce cool air
Old May 24, 2004 | 06:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emong3 &raquo;</TD></TR><TR><TD CLASS="quote">Seems the clutch is slipping. There must be something wrong with the clutch or yuor compressor is starting to sieze.
Another problem maybe that receiver dryer might be clogged which causes liquid refrigerant to enter the suction of the compressor, which causes the compressor to work harder since liquid is basically hard to compress.</TD></TR></TABLE>
Oh noes!!!
We have a bonified A/C master in our midst!
Old May 24, 2004 | 08:29 PM
jdmscg's Avatar
No Sales Forums
compressor could be taking a ****, does it squeak when the a/c kicks in? or all the time? if its all the time probobly belt
Old May 25, 2004 | 12:15 PM
Default Re: A/C Squeek (jdmmunkey)
Agian, it only squeaks when I TURN THE A/C ON.
Old May 25, 2004 | 12:47 PM
yungfab's Avatar
Default Re: A/C Squeek (94CarbonHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CarbonHatch &raquo;</TD></TR><TR><TD CLASS="quote">Mine started doing that, then the clutch died completly </TD></TR></TABLE>
did u get it fixed? if so, what did u need?
ylfotevoli
Apr 11, 2007 02:33 PM
preludebbduce
Sep 23, 2006 05:06 PM
turbod16y7vtec
Feb 24, 2006 11:08 AM
Mi2age
Jan 31, 2006 08:18 PM
95TEG
Aug 19, 2005 08:45 AM
