D15B Difference
Old May 24, 2004 | 04:42 PM
Luiyo's Avatar
Default D15B Difference
How can I find out if my d15b is an normal one 108hp or a stage 3 one 128hp?
Old May 24, 2004 | 04:45 PM
TeamNextGenChris's Avatar
Default Re: D15B Difference (Luiyo)
do you mean the JDM D15 VTEC motors?if so,the OBDI(all the obvious OBDI clues-distributor plugs,injector plugs,etc.)has one VTEC solenoid.if you have the OBDII 3-stage VTEC D15,it will have two VTEC solenoids right beside each other.
Chris
Old May 24, 2004 | 04:50 PM
Luiyo's Avatar
Default Re: D15B Difference (TeamNextGenChris)
Thankx men. Yea it is an JDM D15 VTEC OBD1. What will be the HP in these one?
Old May 24, 2004 | 04:51 PM
Luiyo's Avatar
When I bought it the told me that it has 130hp supposly.
Old May 24, 2004 | 04:52 PM
Ricey McRicerton's Avatar
They're pretty equivelant to a D16z6.
Old May 24, 2004 | 04:54 PM
Luiyo's Avatar
Default Re: D15B Difference (Ricey McRicerton)
So we are talking about 128.something HP. If I'm not mistaking... Am I right?
Old May 24, 2004 | 04:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luiyo &raquo;</TD></TR><TR><TD CLASS="quote">So we are talking about 128.something HP. If I'm not mistaking... Am I right?</TD></TR></TABLE>
The Z6 was rated at 125. Ive heard the motor in question rated around 130, but honestly that 5 isn't going to mean jack in normal driving.
Old May 24, 2004 | 05:04 PM
Luiyo's Avatar
jeje... Im planing on boost it. Is it true that the bottom end is a lot weaker compare to the 1.6?, or are they pretty much the same? I will have to get 1.5 rods, or 1.6 rods?
Thanks for the info.
Old May 24, 2004 | 05:26 PM
Luiyo's Avatar
Bump!!! Anyone...
Old May 24, 2004 | 06:58 PM
solo2slocivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luiyo &raquo;</TD></TR><TR><TD CLASS="quote">jeje... Im planing on boost it. Is it true that the bottom end is a lot weaker compare to the 1.6?, or are they pretty much the same? I will have to get 1.5 rods, or 1.6 rods?
Thanks for the info.</TD></TR></TABLE>
the rods are the same lenght as the 1.6 and pistons i think are also 1.6.... the block itself has the same deck height as the z6 but the crank is different to make it a 1.5.....
i have a d15b in a 92 dx hatch and it pulls hard
earz
16
Mar 15, 2009 03:49 PM
lilredrocket83
Sep 9, 2007 09:58 AM
ebrake08
31
Jun 8, 2005 09:26 AM
B18C5-EH2
14
Jan 19, 2005 08:00 AM
B18C5-EH2
Jan 17, 2005 04:00 PM
