what plug is this for?
Old May 24, 2004 | 01:07 PM
APEX CRX's Avatar
Default what plug is this for?
quick question. 89 CRX Si. the harness that goes under the intake manifold. I am swapping in a B18C1 and there is one plug that I can not account for. It is white and rectangular double wire. it is right next to the oil pressure plug and ECT plug but before the Alternator? anyone? if not I'll have to take a pic of it and post it.
it has a black with yellow strip wire and a blue wire.
Modified by APEX CRX at 12:08 AM 5/25/2004
Modified by APEX CRX at 12:09 AM 5/25/2004
Old May 24, 2004 | 01:52 PM
tilt's Avatar
Default Re: what plug is this for? (APEX CRX)
the fast idle solenoid harness?
https://honda-tech.com/zerothread?id=861649
Old May 24, 2004 | 02:12 PM
APEX CRX's Avatar
Default Re: what plug is this for? (tilt)
hmm. I'm not sure the plug and wire off the harness is no more than 6 inches long. Did the fast idle solenoid have a harness that would drop all the way down to it that far from the Manifold?
Old May 24, 2004 | 02:16 PM
TruSlydHatch's Avatar
Post a picture... Itll make it easier for us all :thumb:
Old May 24, 2004 | 02:17 PM
APEX CRX's Avatar
Default Re: (TruSlydHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruSlydHatch &raquo;</TD></TR><TR><TD CLASS="quote">Post a picture... Itll make it easier for us all :thumb:</TD></TR></TABLE>
ok fine!!!! pic will be up later when I get home
Old May 24, 2004 | 03:55 PM
NCchris's Avatar
Sounds like the plug that went to the thermoswitch that was on the back of the A6 motor next to the oil pressure sensor. If so, it needs to have it's wires unwrapped and extended to the thermostat housing. That is where it resides on the B motors. There is enough wire, just unwrap and snake those two wires out and re-route them. Plug is same.
HTH
chris
Old May 24, 2004 | 11:11 PM
APEX CRX's Avatar
Default Re: what plug is this for? (NCchris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCchris &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the plug that went to the thermoswitch that was on the back of the A6 motor next to the oil pressure sensor. If so, it needs to have it's wires unwrapped and extended to the thermostat housing. That is where it resides on the B motors. There is enough wire, just unwrap and snake those two wires out and re-route them. Plug is same.
HTH
chris </TD></TR></TABLE>
nope sorry, the plugs for the old ECT switch are 2 small male pins. I already extended them to reach the thermoswitch on my B-series. BTW the plugs are NOT THE SAME
Old May 25, 2004 | 04:02 AM
dash's Avatar
evap purge, that is what that plug is on mine. and it is not used
Old May 25, 2004 | 05:59 AM
michael O's Avatar
Default Re: what plug is this for? (dash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dash &raquo;</TD></TR><TR><TD CLASS="quote">evap purge, that is what that plug is on mine. and it is not used </TD></TR></TABLE>
I believe that's how it is on mine too.
Old May 25, 2004 | 06:14 AM
jlicrx's Avatar
that would be for the Fast Idle Control Valve on the Si
Old May 25, 2004 | 06:34 AM
APEX CRX's Avatar
I thought the evap purge is on the firewall next to the map?
Old May 25, 2004 | 01:43 PM
buckNasty's Avatar
yup my purge was on the firewall
and help this guy out people he and i have to go to laguna this summer
Old May 25, 2004 | 02:57 PM
APEX CRX's Avatar
Default Re: what plug is this for? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">that would be for the Fast Idle Control Valve on the Si
where is the valve normally? underside of intake manifold? the wiring is pretty short so I would assume it has to be backside of stock manifold
Old May 25, 2004 | 03:07 PM
tilt's Avatar
sensor on the bottom left.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">
where is the valve normally? underside of intake manifold? the wiring is pretty short so I would assume it has to be backside of stock manifold</TD></TR></TABLE>
Old May 25, 2004 | 03:09 PM
APEX CRX's Avatar
COOL, thanks. that might of been it. as I have long ditched my a6 there is nothing to compare to. I will just leave it unplugged.
Old May 25, 2004 | 04:08 PM
NCchris's Avatar
nope sorry, the plugs for the old ECT switch are 2 small male pins. I already extended them to reach the thermoswitch on my B-series. BTW the plugs are NOT THE SAME</TD></TR></TABLE>
lol, sorry dude, I took my best shot. Now that I see the plug and other posts, my vote is for the fast idle. My crx is a HF and it doesn't have that selinoid or the plug. FWIW, your purge is on the firewall as posted and your map is too. You can ditch both of them and use the B18 map on the throttlebody and the purge right above it on the manifold. (went out and looked at my GSR)
chris
Old May 25, 2004 | 04:15 PM
APEX CRX's Avatar
chris</TD></TR></TABLE>
ha ha thanks. yeah thats what I'm leaning to also on that its the fast idle. Yeah thanks for the FYI on the evap and map. I knew to use the ones off the GSR TB.
tommiboy
Nov 9, 2005 01:21 AM
VTcivicHB
Nov 8, 2005 03:44 PM
underage
11
May 25, 2005 12:41 PM
West Werks
Mar 10, 2005 08:10 AM
JerKeK9
Jan 19, 2005 09:16 PM
