What distibuter do I use for a EG w/1st gen b16???????????
Old May 24, 2004 | 11:15 AM
HNDAPWR's Avatar
Default What distibuter do I use for a EG w/1st gen b16???????????
I need to get a new distributer for my EG but, I'm unsure which one to ask for when I call the parts supply. Which one do I need? Which car would it have been out of so that the plugs match????? I searched and just got a ton of FS, WTB threads.
Old May 24, 2004 | 11:43 AM
Turbogixxer's Avatar
Default Re: What distibuter do I use for a EG w/1st gen b16??????????? (HNDAPWR)
You are running OBD1, right?
You will need 94-95 Teg (GSR) Vtec Dizzy
Old May 24, 2004 | 01:09 PM
HNDAPWR's Avatar
Default Re: What distibuter do I use for a EG w/1st gen b16??????????? (turbogixxer)
Cool. So the 94-95 teg GSR plugs right up, no re-wiring or anything?
Old May 24, 2004 | 01:10 PM
If you are running OBD1 harness, yes (you should be)
Old May 24, 2004 | 01:19 PM
HNDAPWR's Avatar
Thank you sir, it's much appreciated.(It's the factory harness, so I believe that would be obd1)
Edit: to be honest, i'm not positive,. I didn't do the swap.
Old May 24, 2004 | 01:26 PM
It would be just plain dumb if they switched it to OBD0 (which a 1st gen B16 is).
Old May 24, 2004 | 01:29 PM
HNDAPWR's Avatar
This is the one I need correct.(the one in this thread, I hope I did this right)
Far as I know, the cars factory harness was used.
honda-tech.com/zerothread?id=617708
Edit: damn it, I suck. Anyways, I believe you have pointed me in the right direction , friend. Thanks again.
Old May 24, 2004 | 01:43 PM
Funny part of that thread, it is a OBD2 dizzy
It will work if you repin it but...........
Old May 24, 2004 | 01:54 PM
HNDAPWR's Avatar
That plugs on that dizzy look the same as mine, i'm not sure of the pinout though. But you say 94-95 GSR dizzy, huh? I hope thats it. I'm tired of dealing with mine. Going through igniters/coils. I figure if i start off new and If still have problems, it shouldn't be the dizzy.
Modified by HNDAPWR at 4:08 PM 5/24/2004
tougetuned_ef
Engine Management and Tuning
Jun 17, 2010 01:51 PM
jamelin
Oct 10, 2009 04:53 PM
spooledhonda
Feb 6, 2007 12:47 PM
