AZENIS Sport 205/50VR15 TIRE PRESSURE suggestions
Link to Tires
http://www.vulcantire.com/azenis_t.htm
looking for advice on what tire pressure to use
B16a 1990 Crx, LSD, bone stock.
Koni Yellows/Ground Control Springs
i have read on some tires lowering press. too low works in reverse.
My thoughts are 20psi. ?
Modified by issues4 at 1:26 AM 7/1/2004
hmmm....not the same make of tire though? just same size. I think when the tires were mounted for me, it was set at 30-35psi. Pretty high up there.
Thanks for input.
Thanks for input.
Opps sorry no same make of tire and everything. I run 30 on the streets but drop it down to 15 on the track. Some people say you can drop it down to 10 but I have not tried it. I stay between 15-18.
wow...i'll have to give that a shot
you haven't tested with different tire pressures have you? always done 15psi?
From: Canyon mother fucking Country, California, United States of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by issues4 »</TD></TR><TR><TD CLASS="quote">Please ignore the above post. He has been reported to the Mods.
Lets keep Honda Tech informative.</TD></TR></TABLE>
That was damn informative... It is not a drag tire..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by issues4 »</TD></TR><TR><TD CLASS="quote">B16a 1990 Crx, LSD, bone stock.</TD></TR></TABLE>
= 160hp give or take
I have tried a bunch of different pressures going from 25 and working my way down. Just a thought that occured to me. It was 15 psi between runs which prob means if the tire was cold it would be lower then 15 psi. What I did was made a run and lowered it. Then made another run and lowered it again, seeing if my 60 foot got better or worse and how bad I was spinning. My best time was a 2.0 but I only hit that once. At first I was getting like 2.4 then worked my way down to about a 2.1 2.2. I am still learning how to launch but my times and 60 foot have been getting better.
I also noticed if you don't go through the water and just spin them up to the line to heat them up a little bit it seemed to help a lot. I know some people say you just go up and launch on them but I tried burning them a little and i noticed a difference.
I am putting out a little over 300 to the wheels.
For the jerk off that said they are not a drag tire no **** but they work a lot better then my kuhmo's I had on the car and they are a hell of a lot cheaper then buying BFG every 1000 miles.
Hope that helps
Hope that helps
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 »</TD></TR><TR><TD CLASS="quote">
Hope that helps</TD></TR></TABLE>
im not buying BFG's again...great tire
but dont last for anythign on a daily!!!!!
uncleben
Jan 18, 2006 08:23 PM
B_1_8_hatch
39
Dec 8, 2002 06:36 PM
01PYTypeR#1140
Mar 8, 2002 08:38 PM
