Car won't start
Old May 24, 2004 | 08:04 AM
badazzaccrd's Avatar
Default Car won't start
Well, tried to start my car this morning, but no luck. When I turn the key, nothing. Won't turn over, no ticking noises, nothing. This happened yesterday, but started after 3-4 tries. But this morning, nothing. I'm thinking starter, or ignition switch. Any suggestions, before I start working on her?
Old May 24, 2004 | 11:35 AM
JimBlake's Avatar
Default Re: Car won't start (badazzaccrd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badazzaccrd &raquo;</TD></TR><TR><TD CLASS="quote">... starter, or ignition switch. Any suggestions, before I start working on her?</TD></TR></TABLE>Or battery. Or battery cables.
Put a voltmeter on the battery posts themselves (not the clamps). Then try to start while watching the meter. Does it drop way low (below 8v or so)? That would be a bad battery.
Then do the same thing with the meter on the battery cables. If it's OK on the posts but bad on the cables, then clean up the clamps on the battery posts. Then do the same thing with the meter farther along the circuit, till you find something wrong.
Check the starter signal (the little wire at the starter). If it's not getting battery voltage when you turn the key to 'start', that's a bad switch. If it's OK, then probably the starter.
Old May 24, 2004 | 12:16 PM
secksiman19's Avatar
Default Re: Car won't start (JimBlake)
yeah im guessing battery, if nothing at all happens, no beeping or nothing. this sounds like its definetly the battery. check cables(esp the ground) and see if its good. clean em up real well. see if you get any power. how new is the battery you have?
Old May 24, 2004 | 03:01 PM
Thanks for the reply guys. Well I found that it was the starter. Hooked up a remote starter from inside the engine, and tapped on the starter with a hammer, until she finally started.
Old May 24, 2004 | 09:32 PM
omeara7's Avatar
Default Re: (badazzaccrd)
Actually that same thing happened to me when my starter went. I could turn the key anywhere from 1-10 times before it would start. If your electronics seem to be working fine it might be your starter. I got a rebuilt one (lifetime warranty) for like $130 with the core and it was very easy to install.
Old May 24, 2004 | 09:37 PM
.bagged's Avatar
Default Re: (omeara7)
blow in the breathalyser, as long as you blow legit it will go
Old May 29, 2004 | 10:05 PM
DragonTLS's Avatar
bad starter
DatDCboi
Jul 8, 2011 09:49 PM
silentkid
Mar 3, 2010 11:59 AM
pgpunkguy
Jan 22, 2008 11:29 AM
Ph0eNix
Dec 15, 2005 11:58 AM
eg686
Aug 22, 2005 10:16 PM
