Tie Rod bushing question
Old May 24, 2004 | 06:51 AM
Ajax's Avatar
Default Tie Rod bushing question
Ok, I was driving my car yesterday and it started to shake really bad.. so I pull over and check out my tires and there worn down so low on the inside that the steel belts are showing, but the outside still has tread. So I went and got tires and the guys who put my tires on said my bushings are bad. My dad talked to a mechanic he knows, and according to him I can't just replace the bushings, I'll have to replace the whole front end. Does anyone know if this is true? Because I have no idea why it would be. :\ And if it is, do you know about how much it will cost?
Old May 24, 2004 | 10:58 AM
JimBlake's Avatar
Default Re: Tie Rod bushing question (Ajax)
It would be good to know what year/model car you have. But some of the bushings might only be available by buying the control arms, for example. If several are shot, & you have to buy upper & lower control arms on both sides, maybe that's what he means by "the whole front end"... Or maybe he knows that your ball joints are ALSO shot?
CD5B2
Apr 2, 2013 10:45 AM
npmartin
Honda Civic (2001 - 2005)
Apr 26, 2010 02:58 PM
mattscivic1
15
Mar 23, 2010 07:42 PM
essex
10
May 23, 2005 09:41 AM
dan89crxsi
Jan 6, 2003 11:03 PM
