Engine light on
Old May 24, 2004 | 12:17 AM
civicdust's Avatar
Default Engine light on
Ok, so after having returned the 88 civic i had bought ( returned cuz motor had water in it) i went ahead and got me a 89 civic dx. Now, when i bought it the guy told me it needed a tune up. I went ahead and did the following:
*Changed Motor Oil
*Changed oil filter
*Changed spark plugs
thats all i basically did. Once i was finish the light was still on. I doubt its missing anything else, or can it?
i have a stock engine. Will have pics tomorrow. Interior is fine, but the body needs work.
Any help will be greatly appreciated.
Old May 24, 2004 | 02:54 AM
Lil Red CRXsi's Avatar
Default Re: Engine light on (civicdust)
You need to find out Why the light is on before you just start spending money on diff things.Pull down the carpet on the pass side and see what codes it's blinking.Most likely it just in need of a new O2 senser.
Old May 24, 2004 | 03:18 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Engine light on (Lil Red CRXsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Red CRXsi &raquo;</TD></TR><TR><TD CLASS="quote">You need to find out Why the light is on before you just start spending money on diff things.Pull down the carpet on the pass side and see what codes it's blinking.Most likely it just in need of a new O2 senser. </TD></TR></TABLE>
Definitely get the code before you start wasting money on buying stuff you may or may not need, you will save alot of time, hastle, and money.
Old May 24, 2004 | 10:48 AM
civicdust's Avatar
Do i need any kind of special tool to get a code? (im at school, so i cant pull the carpet out now.)
I will do that when i get home.
I was thinking it could be the timing belt. Like i said, i just got the car yesterday and i dont know if anything in it is good.
i will have pics when i get home.
P.S: Dont expect good quality shots
Old May 24, 2004 | 10:54 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdust &raquo;</TD></TR><TR><TD CLASS="quote">Do i need any kind of special tool to get a code? (im at school, so i cant pull the carpet out now.)
P.S: Dont expect good quality shots </TD></TR></TABLE>
Just your muscles. Pull down the carpet and look at the red light that blinks on the ECU. Long blinks equals tenths, short blinks equal ones.
For example, 2 long blinks, and 2 short blinks is "code 22". But before that, you can try to reset the ecu by disconnecting the negative terminal of the battery for about 1 min. Sometimes that clears a code.
Old May 24, 2004 | 11:34 AM
civicdust's Avatar
Default Re: Engine light on (EL Vap133)
Alright man. I will check later on today.
Thanks alot.
Old May 24, 2004 | 11:50 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
For example, 2 long blinks, and 2 short blinks is "code 22". But before that, you can try to reset the ecu by disconnecting the negative terminal of the battery for about 1 min. Sometimes that clears a code. </TD></TR></TABLE>
This doesnt apply to an 88-91.. You just count the blinks.. The codes range from 1 to 16..
Old May 24, 2004 | 01:02 PM
civicdust's Avatar
is this with the engine on? or not?
cuz i put the key all the way up, and i got the following
also, does it repeat?
Long :2
short: 8
and i think it repeats itself
EDIT: i have pics. Low quality, but heh...
http://www.voidout.com/car/
Modified by civicdust at 10:17 PM 5/24/2004
Old May 24, 2004 | 01:23 PM
tgreaves's Avatar
You should just get repeating codes.. Just turn the key on 2 clicks and watch the red light.. I should just do short flashes since this is a obd0 ecu..
Old May 24, 2004 | 02:56 PM
EL Vap133's Avatar
Default Re: Engine light on (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">You should just get repeating codes.. Just turn the key on 2 clicks and watch the red light.. I should just do short flashes since this is a obd0 ecu..</TD></TR></TABLE>
Does that only apply to obd0 d-series ECUs?
Old May 24, 2004 | 06:38 PM
civicdust's Avatar
Alright well, looking at the book ..
i think it has a problem with the airfilter. BUt im not going to worry about it, since i am going to put an air intake on it.
Hopefully it ends up being that and not anything else.
Old May 24, 2004 | 09:16 PM
tgreaves's Avatar
Does that only apply to obd0 d-series ECUs? </TD></TR></TABLE>
Yep...
Old May 24, 2004 | 09:32 PM
EL Vap133's Avatar
Yep...</TD></TR></TABLE>
No wonder, I got rid of that motor/ecu right away and went b-series. lol
Old May 24, 2004 | 10:43 PM
89dxhunchback's Avatar
Must have been the air filter code, hehehe hahaha.... Killing me....
JDMPLEASE
Honda Civic (2001 - 2005)
Jan 14, 2008 11:02 AM
ITR01845
Jul 11, 2005 06:23 AM
KetteringITR
Nov 15, 2004 10:03 AM
rschoener
Jun 20, 2004 05:19 PM
B18CR-X
Nov 11, 2003 06:04 AM
