How do I check my 5 speed trnas fluid?
Old May 23, 2004 | 09:45 PM
89DXDann's Avatar
Default How do I check my 5 speed trans fluid?
How do I figure out the level of the fluid on my 89 5 speed civic trans? what type of fluid do I use? and how much from drain to fill?
Thanks!
Old May 23, 2004 | 09:57 PM
daidilus's Avatar
Default Re: How do I check my 5 speed trans fluid? (89DXDann)
there is a 17MM bolt right behind your passenger side axle, if you take it out, it should leak a little, and there is a bolt with a 17mm that you can remove from the tranny to drain it
Old May 24, 2004 | 12:47 AM
fourthgenhatchB17's Avatar
Default Re: How do I check my 5 speed trans fluid? (daidilus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">there is a 17MM bolt right behind your passenger side axle, if you take it out, it should leak a little, and there is a bolt with a 17mm that you can remove from the tranny to drain it</TD></TR></TABLE>
Make sure you are on level ground too.
InMyProject
Nov 11, 2007 10:13 AM
Damon Reeves
Apr 15, 2007 09:11 AM
vtec25
Mar 16, 2006 06:54 PM
turbotime
11
Jun 25, 2004 08:22 AM
Slammd Sol
Mar 28, 2004 10:21 AM
