Turbo edit
Old May 23, 2004 | 09:07 PM
1boostedgsr's Avatar
Default Turbo edit
Has anyone here heard of turbo edit (engine management)? This is new to me so any info would be great. I heard it is supposed to be good as hondata but alot cheaper. Yes I searched
thanks
Old May 24, 2004 | 07:32 AM
tgreaves's Avatar
Default Re: Turbo edit (1boostedgsr)
I used it on my crx when I was obd0.. It worked great.. What else do you need to know about it..
For more info about doing this go to pgmfi.org..
Old Jun 1, 2004 | 09:45 PM
Default Re: Turbo edit (tgreaves)
How would you say it compares to hondata? Is programing the chips a pain. I heard you have to upgrade chips with every mod.
Thanks
Old Jun 1, 2004 | 10:06 PM
sporkcrx's Avatar
You have a 96 gsr? Is that what you want management on?
Old Jun 2, 2004 | 05:48 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1boostedgsr &raquo;</TD></TR><TR><TD CLASS="quote">How would you say it compares to hondata? Is programing the chips a pain. I heard you have to upgrade chips with every mod.
Thanks </TD></TR></TABLE>
Well you have to burn a new chip when you make a change to the maps.. If you get the 29c256 chips you can reuse them.. If just went to the AEM EMS computer so that I wouldnt have to keep burning chips..
Old Jun 3, 2004 | 06:06 AM
slowpokesi's Avatar
do you have a list of things that are needed to get started.
like what all do you have to do, i have a crx with a b16a obd0
im running a zdyne 1 wire, do i have to buy a chipped ecu to get started with something like this? or can i take the chip out of my zdyne and make turbo edit chips? how much was the chip burner and where did you get it?
Old Jun 3, 2004 | 06:15 AM
tgreaves's Avatar
Default Re: Turbo edit (slowpokesi)
Im not sure what you have to do with the zdyne computer.. I just used a obd0 pm6 ecu and chipped it out and burnt turboedit chips for it..
I used a burner called Willem.. Check them out at willem.org
Old Jun 3, 2004 | 07:19 AM
slowpokesi's Avatar
whats the deal with adding a serial port to the ecu,
can you do real time edits without having to burn a chip each time?
Old Jun 3, 2004 | 07:33 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">whats the deal with adding a serial port to the ecu,
can you do real time edits without having to burn a chip each time?</TD></TR></TABLE>
Err.. I have heard that Jason Parker built something that will allow you to do real time tuning or something like that but im not sure.. When I had the serial port on my ecu it was just for datalogging..
Old Jun 3, 2004 | 08:54 AM
slowpokesi's Avatar
well i just went out to the car, the ecu is a pm8 (hf ecu)
where the socket is at on my ecu, there is a 40 pin chip,
when i looked at my board, the ecu chip is 24 pin, not 28 will turbo edit work on a 24 pin ecu?
Modified by slowpokesi at 5:14 PM 6/3/2004
Old Jun 3, 2004 | 09:58 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
look at my sig for a link
stan
Old Jun 3, 2004 | 10:18 AM
slowpokesi's Avatar
Default Re: Turbo edit (Stan D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D &raquo;</TD></TR><TR><TD CLASS="quote">look at my sig for a link
stan</TD></TR></TABLE>
wow omg your links helped me so much.
EJ8 GSR-T
Apr 9, 2006 11:17 PM
teddy_dc2
Sep 8, 2005 02:39 AM
drift2004
Jan 17, 2005 08:40 PM
xstalkrx
Jul 21, 2004 03:36 AM
vtek4life
Mar 18, 2004 09:32 PM
