sparks turbo kits?
Im lookin at a sparks turbo kit it, it comes with everything i want, and i can upgrade to the hondata fuel management system, anyone ever deal with them? ths is what comes in the kit
Spark Racing 4 into 1 SUS304 Stainless Steel Equal Length Tubular turbo exhaust manifold
Innovative T3/T04E Turbocharger assembly 60 trim / .63ar Exhuast Housing Stage III
Tial Waste gate 38mm (8.7 PSI Spring)
Spark Racing Front Mount intercooler w/ polished cast aluminum end tanks 32x10.5x2.5
BLITZ Super Blow Off Valve
Spark Racing Aluminum Intercooler Charge Piping
Spark Racing Mandrel bent 2.5" high flow down pipe
Spark Racing Mandrel bent waste gate dump tube
255 gph High pressure/High volume intake fuel pump
12:1 Vortech Boost dependent FMU fuel regulator
Intake air filter assembly
Map sensor bypass (Missing Link)
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and T-Bolt clamps
All necessary gaskets
Installation manual
Oil return assembly
Installation manual
Ty.
Nov 30, 2003 10:29 PM
