PISTON? brand?
hi everyone.. I need a piston with 13:1 compression what brand and size should i buy.. car is daily driven.
here's my current setup.
b16B block with a LS CRANK
EAGLE rods (b20)
4.4 gear w/LSD tranny
CROWER CAMS 63402-2--> thinking to buy any suggestion?im on skunk2 stg1 now
EAGLE rods (b20)
<-- Who prefers to use OEM honda pistons... With aftermarket pistons you will have piston slap.
Use CTR pistons or equivalent (depending on what you're building) and mill the head.
can i run these with 93 octane? im thinking of piston size from 82-85mm? will you suggest my cams 63402-2 on a portflow head?
whats the best?
tnxs in advance peeps...
whats the best?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">How are you gonna run that compression daily driven, you have allot of $$$ for race gas!?
ive seen a lot of street setups with 13-13.5 CR on 93 octane. tuning is the key, same as with high hp turbo outputs, without tuning you're fucked.
can't you get custom pistons from JE or wiseco or srp? just call them up and ask how much... personally i'd just go with ctr's, deck the block and mill the head, with a 2 layer HG and you should be up there (just make sure you clay the motor and have enough room..) good luck
</TD></TR></TABLE>ive seen a lot of street setups with 13-13.5 CR on 93 octane. tuning is the key, same as with high hp turbo outputs, without tuning you're fucked.
E-spec Tuner
12
Oct 21, 2003 09:07 AM
E-spec Tuner
Oct 14, 2003 02:47 PM
