what is better??
Old May 23, 2004 | 08:13 PM
theslugbug's Avatar
Default what is better??
what is better, a b16 block with ctr piston inside or a stock gsr block?? please let me know what u think.
Old May 23, 2004 | 08:30 PM
Dan GSR's Avatar
Default Re: what is better?? (alllgo)
1.8 > 1.6
Old May 24, 2004 | 12:23 AM
theslugbug's Avatar
which will make more power tho?
Old May 24, 2004 | 02:01 AM
2000ekhatch's Avatar
the 16 will have higher cr but the 18 will have more tq, it all depends on the application, you'll have more power on the streets with the 18 but the 16 could be happier in a road race car or scca app. plus the 18 will put down a bit more pwr and have a nicer tq curve with minor work compared to the 16 w/ similar mods
Old May 25, 2004 | 11:27 PM
theslugbug's Avatar
Default Re: what is better?? (2000ekhatch)
what will be better on gas and will last longer in the long run?
Old May 31, 2004 | 01:07 AM
either would take alot of abuse, they both are really mild setups, but the main problem with both would be the retainers and springs/valves staying in thier designated locations.
Old May 31, 2004 | 01:14 AM
theslugbug's Avatar
not planning to see anything over 7000+ a lot. 7000k would be the max but on occassion it will maybe see 8500.
would any of these setup make it in the 13s in a 95 civichatch?
Old May 31, 2004 | 01:22 AM
A gsr would not like even the occasional 8500 rpms at the track. sure it would last a while but for the extra $500 you can build your head and not worry about it ever, I grenaded a stock gsr revving too high, its not pretty. Yeah you could easily see 13's w/ bolt ons, tires, and the right wieght w/ just a gsr swap.
Old May 31, 2004 | 01:40 AM
EMO-anthony's Avatar
The GSR would be better but I would get rid of the CTRs and get ITR pistons. Because in the long run you will experience detonation.
Old May 31, 2004 | 02:22 AM
theslugbug's Avatar
Default Re: what is better?? (THAiGuYDc2)
when do u think it would start?? 50k or so?? why would it detonate, i wont rev high.
well, can a b16 with ctr pistons last to 100k??
Old Jun 4, 2004 | 03:50 PM
the motor will last with the right computer/tuning w/ any detonation, but it has to be tuned w/ that high of compression,a stock ecu will not give the proper afr's or timing that a higher compresison motor needs.
GEN2 LS
Jan 6, 2012 12:30 PM
ONISHIMA
Apr 20, 2005 10:13 AM
NiiS
May 7, 2002 10:08 AM
smp534
Oct 25, 2001 10:54 AM
