eeek help, my brakes, wearing wierd!
Old May 23, 2004 | 07:52 PM
BrandonClaps's Avatar
New User
Default eeek help, my brakes, wearing wierd!
OK so i heard a weird noise today coming from my rear brakes, i did a visual and the pads on the outside looks perfect, so i took the wheels off removed the caliper and looked at the ones on the insides and one side was ALL the way down scraping the metal thingy, and the other side, part of it was all the way down and part of it was up, it was wearing abnormally. I just replaced all brakes and rotors with OEM stuff last year. Fronts are fine, wtf is going on with the rear?!?!?!? HELP!
Old May 23, 2004 | 10:26 PM
Bbasso's Avatar
Default Re: eeek help, my brakes, wearing wierd! (BrandonClaps)
sounds like a frozen caliper...
see if the caliper is sliding freely on the bracket.
But what do I know.
Old May 24, 2004 | 08:11 AM
New User
i lubed the sliders when i did these to, they slide fine ;[
Old May 24, 2004 | 08:30 AM
.RJ's Avatar
.RJ
Replace the pads... rebuild calipers if you want, although may not be worth the time/effort if you use cheap pads in the rear.
The pads that were on my car looked to be originals and had some meat left @ 62K.
Old May 24, 2004 | 08:46 AM
New User
Default Re: eeek help, my brakes, wearing wierd! (.RJ)
for brakes ive used ALL OEM parts right from the dealership.
Old May 24, 2004 | 08:48 AM
MattD@Stoptech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrandonClaps &raquo;</TD></TR><TR><TD CLASS="quote">for brakes ive used ALL OEM parts right from the dealership.</TD></TR></TABLE>
It sounds like j00 didn't align the tabs on the pads with the slots in the pistons...that's usually the no.1 cause of unusuall rear brake pad wear...
HTH
Old May 24, 2004 | 09:09 AM
markpaco's Avatar
I've had that happen to me before on the rear calipers. It appeared that the pad got bound in the slots in the caliper. No biggie. Just bought new pads and was off.
Old May 24, 2004 | 01:40 PM
New User
Default Re: eeek help, my brakes, wearing wierd! (markpaco)
i didn't know they had to be lined up with anything? :confused:
explain more/pics if possible please
Old May 24, 2004 | 01:55 PM
.RJ's Avatar
.RJ
There's a small pin on the back of the pad. Has to line up with one of the slots in the caliper piston..
Old May 24, 2004 | 05:04 PM
New User
but since the piston comes out counter clockwise, wouldn't that move the pad at all unlike the fronts just coming straight out?
Old May 24, 2004 | 05:05 PM
.RJ's Avatar
.RJ
I dunno, I just install them the right way and dont think about it
Old May 24, 2004 | 06:27 PM
The piston doesn't rotate when pressure is applied to the caliper...J00 only rotate it in to get the pad in...
babzog
Honda Civic (2001 - 2005)
May 22, 2008 09:49 PM
Jimmy
Jul 12, 2007 04:19 AM
CrazyModGSR
Jun 13, 2004 06:44 AM
ScootinIntegra
Feb 16, 2004 03:59 AM
1hotintegra
10
Aug 7, 2002 07:01 PM
