which head gasket to use?
Old May 23, 2004 | 06:57 PM
gundamgsr's Avatar
Default which head gasket to use?
i am in the process of building my head over. i have dual valve springs, titanium retainers, skunk 2 stage 3 cams and a port&polish.
i need to up the compression to go with the head. should i just get h/c pistons? or a thinner head gasket? which gasket would do?
i cant really afford to do the block right now, but if i should definately go with pistons, i will save more.
thx
Old May 23, 2004 | 07:21 PM
XtremeCarTuner's Avatar
Default Re: which head gasket to use? (gundamgsr)
Since your head is removed from the block and your best bet right now would be getting a thinner head gasket.. not unless you would want to dish out money to do the block with high compression pistons... thats just my opinion.
Old May 23, 2004 | 10:30 PM
PIC Performance's Avatar
No headgasket out there, no matter how thin, will give you enough compression to run Skunk2 Stage 3 cams.
I'd say save up for some quality forged pistons, sicne id doesn't seem like you're skimping on your engine at all.
edit: btw if you're considering it, I've heard bad things about milling the head for compression purposes. Afaik it should only be done when absolutely necessary, like in the case of a warped head.
Old May 23, 2004 | 10:42 PM
MajorPayne's Avatar
Default Re: which head gasket to use? (Noob4life)
stock honda head gasket, a new one of course, does the job fine
Old May 23, 2004 | 10:45 PM
Default Re: which head gasket to use? (MajorPayne)
Not if he wants to use the hg as the sole means of upping compression to run skunk2 stage3's.
Old May 23, 2004 | 10:48 PM
MajorPayne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noob4life &raquo;</TD></TR><TR><TD CLASS="quote">Not if he wants to use the hg as the sole means of upping compression to run skunk2 stage3's.</TD></TR></TABLE>
very true, but using a hg as the only thing upping your cr seems like a waste of time to me, its not going to do enough by itself to make a big difference
Old May 23, 2004 | 11:14 PM
jDMJeRk's Avatar
you can never go wrong with OEM. You know it will last. From what Ive read even the Golden Eagle headgaskets are OEM just bored out to fit the desired mm of your pistons/bore
monster_c
Apr 5, 2012 09:53 AM
vajdmeg
Jan 30, 2009 11:01 AM
ls_bitik
Aug 9, 2007 08:22 AM
Morhpeous
May 24, 2004 07:19 PM
