Removing the grill on 94-97
Old May 23, 2004 | 05:47 PM
spoolindc2's Avatar
Default Removing the grill on 94-97
i have seen it done before and i was just wondering when you cut out that center piece weather there is going to be a hole... Could someone who has done this post pics as well... much appreciated..... should look like this ----->
Old May 23, 2004 | 05:53 PM
shermanyang's Avatar
Default Re: Removing the grill on 94-97 (rjride1020)
Yeah i would like to know as well...i want to cut mine out so my FMIC gets the full cooling effect!
bump
Old May 23, 2004 | 05:54 PM
DC4noMore's Avatar
I don't have any pics but there will be an open hole. You'll be able to see a few ac lines, the condensor, and your horn. It looks alright if you take your ac out. Just be really careful when cutting around the edges - be as smooth as possible. It would be better if you could sand it down and then repaint it. Good luck.
Old May 23, 2004 | 05:57 PM
Default Re: Removing the grill on 94-97 (DC4noMore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4noMore &raquo;</TD></TR><TR><TD CLASS="quote">I don't have any pics but there will be an open hole. You'll be able to see a few ac lines, the condensor, and your horn. It looks alright if you take your ac out. Just be really careful when cutting around the edges - be as smooth as possible. It would be better if you could sand it down and then repaint it. Good luck. </TD></TR></TABLE>
sounds good. i just hope it doesn't look ghetto after i'm done...cause if it does, i'm gonna get a ITR front and call it a day.
Old May 23, 2004 | 06:21 PM
tdotteg's Avatar
Default Re: Removing the grill on 94-97 (shermanyang)
it will look like this..
there will be a hole where that middle bar is attached. It's not too noticeably on my car cuz it's black, but if you're car isn't dark coloured, i'd say get it shaved by a bodyshop or something. Good luck
Old May 23, 2004 | 06:47 PM
Trance minister's Avatar
Default Re: Removing the grill on 94-97 (tdotteg)
Car looks good in black with that CF lip I had to modify my front bumper to fit my FMIC as well and just used a dremmel tool with a Roto-Zip bit to cut the uerethane, then I went back over it with a dremel sanding drum tool to remove the little fuzzy things that cutting it leaves. the maybe even hit it with some sandpaper and you won't even know it was cut
Old May 23, 2004 | 08:55 PM
MasterSaif's Avatar
damnnnnnnnnnnn that teg is slammed .looks nice
Old May 24, 2004 | 08:55 AM
spoolindc2's Avatar
what did you do about the holes where you cut out that cross member (the colored part of the grill). I was thinking of just mudding it up and sanding it down then repainting the entire bumper. Plus i have a new lip to go w/ it..... keep the pics coming
Old May 24, 2004 | 10:46 AM
crawdad689's Avatar
Default Re: (rjride1020)
sooooooooo slammed
Old May 24, 2004 | 12:05 PM
The Nightwatchman's Avatar
umm that lip isn't gonna last long when that close to the ground, it's almost touching in the first pic
Old May 24, 2004 | 01:19 PM
tdotteg's Avatar
Default Re: (-Weapon-)
keep in mind these are driveway pics. so it gives the slammed look.. it's not that low
Old May 24, 2004 | 02:56 PM
eric8876's Avatar
Default Re: (tdotteg)
OMG thats the sexiest pic ive ever seen of a teg...ya that CF lip is done in about 2 weeks
Old May 25, 2004 | 10:07 AM
AllMotorDan's Avatar
You think you can email me some more pics of your front bumper, i have a white integra and want to do the same, what do you think?
Old May 25, 2004 | 10:20 AM
Chris's Avatar
Default Re: Removing the grill on 94-97 (spoonitrs)
I will lose support and rigidity.
Keep it.,,
Appearance forum
Old May 25, 2004 | 11:47 AM
Kutsuju_SLeePER's Avatar
Default Re: Removing the grill on 94-97 (Chris)
Damn...Nice Work man
Im doin mine this week hoepfully..Ill throw up pics once finished
NewBorn_EG
13
Sep 20, 2010 01:49 PM
GraphiteMW
Mar 15, 2007 08:33 AM
SD_Lurker
Dec 15, 2005 06:20 PM
4thgenlude
Oct 27, 2004 07:33 PM
Tinker219
Jun 27, 2003 10:03 PM
