Integra dash people HELP!!!
Old May 23, 2004 | 05:17 PM
HybridHatchC1's Avatar
Default Integra dash people HELP!!!
MY swap is basicly done i just ran into a few problems.
1. my tach doesn't work, even before the dash swap i tried putting in a aftermarket tach because i didnt have a stock one and it still didnt work. I was wondering if i have a to add a wire or somthing. the car is a 92 hatchback dx.
2. my speedo doesn't work.
3. my clock and radio don't work> i checked the fuse for the radio and cig lighter and its fine. the cig lighter even works!
Info: 92 hatchback dx
GSR dash and harness, i moved the 2 wires to the green plug and matched the rest of the pinouts with the stock civic grey plug.
any help would be appreciated...
Old May 24, 2004 | 05:37 AM
Default Re: Integra dash people HELP!!! (HybridHatchC1)
bump please i need some help!
Old May 24, 2004 | 05:40 PM
bump ....heeelllp i need to know how fast i am going
Old May 25, 2004 | 04:14 AM
bump help!!!! please
Old May 26, 2004 | 06:42 PM
bump
Old May 26, 2004 | 07:04 PM
EzCruiser's Avatar
no blown fuses? mixed up wires? missing wires??
Old May 26, 2004 | 07:50 PM
JDMlyfestyle's Avatar
i think u might have mixed up the pins for the speedo and tach
Old May 26, 2004 | 09:29 PM
hialeahzbg's Avatar
i wood like 2 put a teg dash on my eg it will fit perfect and i will also need the door panels rite?
Old May 26, 2004 | 09:30 PM
hialeahzbg's Avatar
u have any piks of ur car i wood like 2 see im very interested
Old May 27, 2004 | 06:59 AM
Default Re: (hialeahzbg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg &raquo;</TD></TR><TR><TD CLASS="quote">i wood like 2 put a teg dash on my eg it will fit perfect and i will also need the door panels rite?</TD></TR></TABLE>
fitment is based on how patient you are...mine yea its about perfect. and for the door panels i am still working on them but i am cutting them and refiberglassing...also i built up a foam ramp where the panel meets the dash up top because the door panel sat lower then the dash.
still need help guys
Old May 27, 2004 | 07:16 PM
Default Re: (HybridHatchC1)
did anyone ever make a diagram of what should be pinned in the civic grey plug when doing the swap? still having troubles people
Old May 27, 2004 | 07:19 PM
drunknbass's Avatar
clock and radio wont work if you dont have constant power running through the yellow wire.. test that and see if it does.. it should always be a source of power.. so that should solve that problem.. as far as the speedo i dont want to just start guessing.. i did this swap to my hatch like 2 years ago and it always had bugs. when one thing fixed another would bug out.. all i can say is make sure the harness has a GOOD ground
Old May 28, 2004 | 10:46 AM
Default Re: (drunknbass)
i have like 3-4 wires that dont match(or the civic fuse box plug doesnt have) Orange which is speedo, a blue and red wire, and a tealish green wire. i check the yellow everything is fine.
Old May 29, 2004 | 08:37 AM
still no luck people help me!!!!
Old May 29, 2004 | 11:28 AM
speedo, tach, radio, and clock still not working...honda-tech doesn't want to leave me with this do they?
Old Jun 1, 2004 | 07:11 AM
can somone just take a picture of their gray plug...also where are the grounding locations for this harness, i am still haveing problems people
Old Jun 1, 2004 | 07:27 AM
splitime's Avatar
Was your tach/speedo working before?
All I did for my swap was tap power for the hazards. And for the 3rd plug that doesn't just plug right in... i trimmed the 2 extra pinouts that would keep it from fitting and just stuck it in there.... works.
Old Jun 1, 2004 | 03:03 PM
Default Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">Was your tach/speedo working before?
All I did for my swap was tap power for the hazards. And for the 3rd plug that doesn't just plug right in... i trimmed the 2 extra pinouts that would keep it from fitting and just stuck it in there.... works.</TD></TR></TABLE>
gotcha but i fucked the integra plug up... now i repined the stock gray plug everything is in the right place but... there are 3 wires that dont have a place, 1st.a solid yellow 2. a blue with red strip(cruise control?) 3rd. the abs? i know i dont need Cruise control or ABS, but i dont know what to do with the solid yellow. even though i still think my clock and radio should work. and aleast the speedo.
My car never had a tach to begin with/but the speedo worked just fine.
maybe its the grounds? anyone know where the harness should be grounded? also should i run a new tach signal wire? i dunno i am getting really frustrated and fed up with it. i would just like some help to get this done. thanks for all the posters in this thread.
Old Jun 1, 2004 | 03:11 PM
JDMH22HATCH's Avatar
Damn buddy, still having problems? Give me a call tonight and we can go over the pinouts from my car and yours. 214-766-2517
Brandon
Old Jun 1, 2004 | 06:01 PM
Default Re: (JDMH22HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH &raquo;</TD></TR><TR><TD CLASS="quote">Damn buddy, still having problems? Give me a call tonight and we can go over the pinouts from my car and yours. 214-766-2517
Brandon</TD></TR></TABLE>
i will take the offer, i guess i will give you a call tommorrow in the evening and see if we can work this out.
Old Jun 1, 2004 | 09:39 PM
IVI's Avatar
IVI
plug in the old cluster to make sure everything is working first.
GdmLaz
13
Sep 11, 2005 12:53 AM
DCWheat
Sep 17, 2004 04:58 AM
HybridHatchC1
May 19, 2004 04:46 PM
B18Cej1
Mar 30, 2004 04:52 PM
92B20GSR
Oct 16, 2003 06:10 PM
