Question about integ rear disks on my car...
I got my set of rear disks from a 93 integra with ABS, and I'm having a few issues.
First of all, I'm pretty sure the wheel bearing are bad, it's ALWAYS making a roaring sound from the rear like the tires are fighting each oter going down the road... Also, my rear backspacing doesn't seem to be the same as the front anymore. Wheels of the same backspacing don't fit qite right in the wheel wells in the back and SCRUB BADLY.
This is all after I've had my alignment done twice!
Anyway, is the backspacing on a antilock rear disk different from the backspacing on a non ABS rear disk?
How much should I be willing to pay to have both rear wheel bearings replaced?
Thanks guys!
[Modified by SiR Kid, 8:39 PM 11/8/2001]
This is all after I've had my alignment done twice!Anyway, is the backspacing on a antilock rear disk different from the backspacing on a non ABS rear disk?
Thanks guys!
SiR Kid-Integra r trailing arms have different geometry-offset.Take the Integra disc brake hubs off the Integra trailing arms and bolt them to your EF trailing arms.I have this-it works.You need like a Torx T51(I think) and a 24mm socket in addition to your usual metric tools.The noise you hear may be rubbing.Be very careful w/the T51s-very easy to strip!Hope this helps.
delsolo95
May 19, 2012 11:12 AM
