changed timing belt, now car wont start
Old May 23, 2004 | 03:47 PM
GroundZer0 336's Avatar
Default changed timing belt, now car wont start
ok, today i snapped my timing belt, towed it to my friends house and ripped it apart, put a new timing belt and waterpump, timing looks about perfect, put everything back together cranked it, and it turned on, but died like 10 seconds later, i dont have much gas and the car is all jacked up and stuff so we put more gas, now it only cranks and does not turn over...
still have spark on all plugs and wires. but when we pulled the plugs they were mad black and ****. they were white before.
so if my timing is off, why would it have started in the 1st place? we're about to turn either the crank pully or the cam gear one whole time and back to tdc.
somebody helP!!!
Old May 23, 2004 | 04:17 PM
civickiller's Avatar
Default Re: changed timing belt, now car wont start (optimus_prime)
i would put it back to tdc and check timing again, posbbily you forgot to torque the tension down and it jumped which is why it ran, jumped then died. i would do also do a compression test on the motor
Old May 23, 2004 | 04:32 PM
c jackson's Avatar
threes
Default Re: changed timing belt, now car wont start (civickiller)
compression check
Old May 23, 2004 | 05:47 PM
Default Re: changed timing belt, now car wont start (c jackson)
ok well i got it running, but not well. i thought the tdc of the crank was the single line, but well its not... so i put that right and it started up and everything.
but now, when i try to go, it doesnt really go....it just kinda puts along then as the rpms rise it accelerates faster. so i guess ill mess w/ the timing alot tomorrow see if i can get it right.
any tips?
Old May 23, 2004 | 05:53 PM
Redline130's Avatar
Hopefully you didn't do any damage to the valves.
Old May 23, 2004 | 07:06 PM
juanb's Avatar
Default Re: changed timing belt, now car wont start (Redline130)
yea man hopefully u didnt bend any valves.. i busted a timing belt while driving and replaced it i started it up and it suddenly died.. belt was off by a tooth or two.. fixed it then ran pefect.. i changed it about 3 times then got it right.. just play with it a little bit
Old May 23, 2004 | 07:22 PM
Bee17hatch's Avatar
Default Re: changed timing belt, now car wont start (juanb)
yea like the other guy said double check the timing and do a compresion test to make sure you didnt bent any valves.
Old May 24, 2004 | 07:48 AM
Default Re: changed timing belt, now car wont start (Bee17hatch)
my valves are fine, i tested that, right when the belt broke my car turned off and i wasnt on the gas or anything when it happend, so hopefully it didnt mess anything up, but my valves seem fine. but as for the timing i just gota play w/ that after work today.
Old May 24, 2004 | 10:53 AM
how did you test if the valves were fine ?
but if your car is stutter and running really bad, either yoru timing is off or you bent a valve, because either one will cause your car to run bad.
i still recommend to check timing again and then to do a compression test
Old May 24, 2004 | 11:02 AM
BLT2FLY's Avatar
Agree with civickiller.. Check it again.
Old May 24, 2004 | 11:38 AM
technine's Avatar
Default Re: changed timing belt, now car wont start (BLT2FLY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLT2FLY &raquo;</TD></TR><TR><TD CLASS="quote">Check it again.</TD></TR></TABLE>
Old May 24, 2004 | 12:40 PM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">how did you test if the valves were fine ?
i still recommend to check timing again and then to do a compression test</TD></TR></TABLE>
Same thing happened once on a guys D16, the bad part was after it was torn down, it had bent 4 intake and 4 exhaust valves cause the timing was severely off. CHECK AGAIN
Old May 24, 2004 | 01:01 PM
EG8R's Avatar
Default Re: changed timing belt, now car wont start (HybridHatch88)
The belt is one tooth off. I've messed with the timing on my car and thats what is did. Putt putt putt and then all of a sudden it accelerates quickly. Turn the cam towards the front of the car. Should solve it.
Old May 24, 2004 | 09:27 PM
Default Re: changed timing belt, now car wont start (skelly ed666)
yup i put it back one tooth, and it seems fine, my friend says it feels faster, but i think it still feels slower than what it was.... i duno.
its running good enough to get to and from work so its good for now.
thekeysarebroke
15
Oct 1, 2012 05:35 AM
sd619jef9
18
Aug 25, 2012 10:35 AM
Jack Shephard
12
Feb 13, 2009 06:27 PM
nighttrain33
Mar 23, 2008 01:38 PM
specv5150
11
Oct 7, 2004 02:39 PM
