No spark from ignition wires..... what could be wrong?
Old May 23, 2004 | 02:12 PM
btrim23's Avatar
Default No spark from ignition wires..... what could be wrong?
as the topic stated, there isn't any spark from the ignition wires. I have taken the whole distributor to test on another prelude si and it work. external ignition coil does work. where am I not getting spark from? timing is correct, car just doesn't crank alive. Please help.......
Modified by btrim23 at 8:14 PM 5/24/2004
Old May 23, 2004 | 06:16 PM
TruNinja619's Avatar
Default Re: No spark from ignition wires..... what could be wrong? (btrim23)
have you tried replacing the ignition wires????
if you need an external coil... i can sell you mines for $50...
Old May 23, 2004 | 06:29 PM
c1civic's Avatar
sent pm
Old May 24, 2004 | 05:20 AM
gerhard's Avatar
It could also be your ICM (Ignition Control Module) or "Ignitor."
Located in the distributor... This is what jumps the voltage up to be powerful enough for the spark to jump the gap.
Failure of this item will also cause the tach not to work properly (if the car was actually running)l
Old May 24, 2004 | 07:16 PM
btrim23's Avatar
gerhard, I appreciate your help but if it's the ICM then wouldn't the distributor not work in another prelude when I test it?
Old May 28, 2004 | 08:53 AM
btrim23's Avatar
well, the car was towed to a shop. they found out that it was some kind of ground. but great....... My car is back.
lion civic
Sep 24, 2017 12:22 PM
808DA
Mar 26, 2009 05:24 PM
cardioid
Mar 13, 2009 09:04 PM
bigtom388
Jun 10, 2008 11:53 AM
jaskuloski97sh
Jul 1, 2007 09:12 PM
