Tach hardly works
Old May 23, 2004 | 01:44 PM
Mantis88ls's Avatar
Default Tach hardly works
The stock tach in my 89 crx si hardly works at all, it jumps around alot and when im cruising at about 60 sometimes it will completly stop working, i cant take the car to redline cuz the tach jumps so bad that i never know what rpm im at. someone tell me what i can check too see if i can fix this?
thank you
Old May 23, 2004 | 01:55 PM
Mantis88ls's Avatar
Default Re: Tach hardly works (Mantis88ls)
ohh yea forgot to mention, we changed out the distributer and still have the same problem.
Old May 23, 2004 | 04:39 PM
Mantis88ls's Avatar
bump
Old May 23, 2004 | 04:41 PM
j_max420's Avatar
if you changed the distributor there is a high possibility the problem is in the cluster, get a wiring diagram and follow the wire and check for any loose connections or broken wires.
Old May 23, 2004 | 09:13 PM
Bgladfelter's Avatar
Now, when the tach is jumping, does the motor feel like it is jumping? When you say it won't go to redline, does it die before it, or you just cannot see it climb there?
ramco
Mar 6, 2010 07:30 PM
MeatballHB
Dec 14, 2005 11:55 AM
frostee trooper
Feb 6, 2005 10:58 PM
OneThirtyEight
Jan 10, 2005 06:05 AM
rice is nice
Dec 7, 2004 10:26 AM
