Why Honda's are so bad on Transmissions?
Before I ever had a Honda, I used to hear nothing but good things about how Honda's are great cars and they last forever. Since I bought mine, my transmission was acting up etc. Now, I've heard of a lot of them acting up. I guess it was all hype with these cars. I love my car but I guess I had my expectations up too high.
and also some people just drive wrecklessly, forever flooring at everylight, dropping the gears like its a manual, etc etc...
take it easy and drive a little normal and the tranny should last ya a good 150k or more before any signs of wear
With the exception of the 6th gen V6 trannies, honda autos are pretty damn good.... -IF- you keep the fluid clean. Being that there is no filter (at least on some of them, not sure about all), it is very important to keep it clean. Honda autos are very very picky about staying clean. Heat is also one of the biggest killers of auto trannies, so if you're always running it hard with no cooler, then your tranny is gonna fry. You'd be suprised too, it only takes about 40 degrees above normal operating temp to totally fry an auto tranny. If the fluid is regularly changed (like it's supposed to be) and you don't drive it hard without a cooler, then honda autos last a very long time. There's an 87 Accord sitting in my driveway right now with 302,000 miles on the original auto tranny, and it's never once been touched except for regular fluid changes since new. Still shifts like new.... firm yet very smooth, and doesn't slip one bit. My dads SE-i is at 155,000 miles and it too shifts beautifully. Neither of these trannies show any signs of slowing down anytime soon.
Just keep the fluid changed and they last just fine
Thanks guys for all your input. But now i'm going to ask a stupid question....LOL What is a tranny cooler? I never heard of that. I would like to purchase it if it's going to make things better. I just got my trans flushed at Honda where they did almost 90% of all fluid.
A tranny cooler is like a mini radiator attached to the front of the radiator that allows tranny fluid to transfer the heat to coolant, in turn the heated coolant dissipates in the radiator like the rest of the coolant in the engine. Basically, it transfers heat from the tranny in the fluid to the coolant to be dissipated.
my 2001 4 cyl automatic with 34k miles just had the engine light come on & D4 tranny light started flashing.
The RPM's went up but the car went NOWHERE..
it SLOWLY started to move and now when i first start it the rpm's go up and it slams into first.
YES, i wonder why HONDA"s are so bad on Transmissions too.
I'll find out what the deal is after i drop it off to honda dealer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">like most cars, AT get bad with age.......if u change fluid regularly, and invest in a tranny cooler, itll last </TD></TR></TABLE>
What's the interval on the fluid changes?
Can someone post the price on the tranny cooler?
Thx.
Thx.
the reason why you hear about it is cause you are on a honda board that is about performance performance. we drive our cars hard, when you do this it can put more strain than what the tranny was designed for. this is especiallu true for auto trannies. i'm sure if you drove an auto tranny normally like the rest of the honda average honda owners you wouldn't have a problem, except for the known tranny issues with the 6th V6 and the Sport Shift trannies.
So the J30A1 is the problematic transmission? I would also like some info on a tranny cooler. Just bought the V6 and now I am starting to get a bit worried.
I do agree with the point made by KGAccord though.
http://www.partsamerica.com
I bought my cooler at advance auto...same as partsamerica
looking for an inline filter also
I've got 248k on my 91 Accord and it still shifts perfectly fine. You have got to be strict with maintenance...if you don't do the changes with your fluids, things will start breaking...that goes for any car, not just Hondas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by astrochimp »</TD></TR><TR><TD CLASS="quote">
I'll find out what the deal is after i drop it off to honda dealer.</TD></TR></TABLE>
From Service Bulletin 02-062:
Applies To: 1999–01 Odyssey – ALL
2000–01 Accord – ALL
2000–01 Prelude – ALL
BACKGROUND
In certain vehicles, a higher than normal number of
automatic transmissions may have defects in material
or workmanship that could cause premature wear or
failure. To ensure that customers have adequate
warranty coverage, American Honda is increasing the
warranty on the transmission and the torque converter
to 7 years or 100,000 miles, whichever occurs first.
BACKGROUND
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
BACKGROUND
automatic transmissions may have [QUOTE=Chiovnidca]
BACKGROUND
to 7 years or 100,000 miles, whichever occurs first.</TD></TR></TABLE>
It's all those workers driving Nissans and Toyotas I tell you--
BACKGROUND
BACKGROUND
I want to buy an oil and tranny cooler, do you buy them as universal parts or are they to spec, cause I know that greddy makes an oil cooler for 5th gen accords but not for 6th, could I use that.
BACKGROUND
ThanKS!
BACKGROUND
ThanKS!
The last 3 cars I've owned were Civics. In my opinion Hondas are amazing durable cars until my most recent one which I unfortunately made the mistake of buying an automatic. The transmission has been absolutely bitter to me, I am about replace it with fresh atf and a new filter hoping this works. I was curious about flushing it but I've read some bad things about flushing, so I wanted to ask what have some of you experienced from transmission flushing? Is it worth doing?
Please start your own thread with relevant car info. in the correct sub-forum.
ITR1071
Oct 3, 2002 04:11 PM
