Si Tranny Swap!!
I have a 93 ex coupe with an automatic transmission, i also bought a 95 Si manual tranny for it. i want to swp them and i have the shift linkage, all pedals, shifter, clutch pump, and all tranny compnents. The only thing i need to know before doing this is if i need a new ecu. For instance the ecu in my engine bay reads P28, but the number on the tranny is P20, do i need to swap the ecu as well? and what needs to be done to do the swap? i hear that the dash needs to be removed..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">From now on "search *******" or anything of this sort without posting a link will get points docked immediately.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=873181
you will need a manuel ecu.
I didn't need to remove my dash, you also need the slave cylinder for the hydo tranny, I changed the computer on mine, but I also did a mini-me, so I'm not too sure about that. You will need the motor mount brackets that fit on the trans, upper and lower. Flywheel cover. You will have to cut out where the automatic shift cable comes out because the shift linkage will hit the metal. Cover the hole with some sheet metal and some rtv. You will also need to wire in the back up switch/light......blabla bla I dont know there is so much to list. Good luck!!
big-cat
Mar 14, 2008 08:57 AM
