Need help Idle problem, car constantly Idles at 1000 and revs to 2500 or 3000.
Old May 23, 2004 | 09:27 AM
holeymoly's Avatar
Default Need help Idle problem, car constantly Idles at 1000 and revs to 2500 or 3000.
I have a B18C1 with CTR pistons, AEM COI, Whalbro fuel pump, DC header and Tanabe Exhaust. The car started out just idling and reving to 2000 to 2500rpms like it would hold for a sec then drop back down. Aftrer about 10 min it would stop. I took it to the track and after a run or too. Now it idles and revs to about 3000 and drop down then back up again constantly. I woke up this morning started it and it wont stop the idle. It pissing me off. I look like a dumb *** at a light.
I also have a little blow by rings are getting a little bad. Please help ASAP.
Old May 23, 2004 | 03:20 PM
PurpleDC2's Avatar
Default Re: Need help Idle problem, car constantly Idles at 1000 and revs to 2500 or 3000. (holeymoly)
that sucks is it going all of the way down or is it just stuck at 3000? Check your throttle body to see if it is open at all or stuck. you can also check your idle control valve on the back of your manifold, that whont let in that much air but take it off and make sure that the little flipper is moving.
Old May 23, 2004 | 06:14 PM
holeymoly's Avatar
Default Re: Need help Idle problem, car constantly Idles at 1000 and revs to 2500 or 3000. (PurpleDC2)
I fixed it hell yea. Thanks for the help though . I took the FITV out and fixed it, idles about 800 rpms now.
dlncooke
Honda Fit
Apr 7, 2013 08:05 PM
JDM-ish
May 17, 2007 08:13 PM
drisken
Sep 9, 2004 09:41 PM
D16a6 2NR
Nov 28, 2003 11:21 PM
Eurasia00
Apr 22, 2002 11:37 AM
