Usefullness ? on parts I found at local store......Vacuum Manifold and Light Battery
Old May 23, 2004 | 09:07 AM
Jays91DXhatch's Avatar
Default Usefullness ? on parts I found at local store......Vacuum Manifold and Light Battery
Ok, so I'm at a local store called Princess Auto..not sure if they have that in the US, but anyways, they always have cool stuff there other then cheap tools.
I found:
-Hawker SBSJ16X battery, I have seen some posts and I think this is the battery they were talking about, maybe the 13X which is lighter, but my car will have an alarm. No stereo..but an alarm So I'm wondering if this would work well?
It also says "Charged august 2002" on it..would that matter?
This thing was going for a whopping 59.99$ CDN...about 45$ US.. what do you think? worth it?
-I also found this Vacuum manifold they have on sale, they are made for air compressors....check out the pics:
It's got 1/2 inch NPT in/out, and 4x1/4 NPT outlets. I'm thinking of using the 1/2 NPT for the brake booster and the 4x1/4 inch NPT for wastegate, BOV, boost gauge..whatever else.
What do you think of this thing? It was 10$ CDN... like 7.50$ US cheaper alternative then Golden Eagles.
They also had power door lock actuators..2 for 10$CDN of course. Will go well with the alarm, and I can remove most of what's inside the door. They are light as well.
Old May 23, 2004 | 09:12 AM
toxicshit's Avatar
Default Re: Usefullness ? on parts I found at local store......Vacuum Manifold and Light Battery (Jays91DXha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jays91DXhatch &raquo;</TD></TR><TR><TD CLASS="quote">
-I also found this Vacuum manifold they have on sale, they are made for air compressors....</TD></TR></TABLE> wow dude thnx for the info. ill have to look for one.
Old May 23, 2004 | 08:11 PM
So...you guys think this Vac Mani will work well or what?
And the battery? It's damn cheap for these things.
Old May 23, 2004 | 09:00 PM
int3gra's Avatar
You should also check out CISCO parts store as well, they have everything.
krazyhmongboi
Dec 20, 2006 07:08 PM
93civicsedan
Audio / Security / Video
Oct 10, 2006 10:52 AM
phateless
May 28, 2006 05:29 AM
.water
Jul 30, 2005 06:39 PM
enabi
Aug 25, 2002 01:44 PM
