gear shift is not smooth at high RPM...why n how to solve it?????
i'm using EF8 with b20 engine and ys1 tranny. i also using exedy clutch and clutch plate (3 puck). the shifting is smooth at lower RPM but when it reaches 9000 and above, it is hard to shift the gear and i have to drop the RPM to 8000 - 8500. other wise i'll miss gear. this is happen when i shift from 1st to 2nd only.
please help. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">try putting some gm synchromesh in there.
above 9000 rpms hugh? what cams do you have?</TD></TR></TABLE>
hehe, i was wondering the same thing.
cam?? JUN Type 3 with valve spring and retainer(http://www.junauto.co.jp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir_acap »</TD></TR><TR><TD CLASS="quote">i'm using EF8 with b20 engine and ys1 tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir_acap »</TD></TR><TR><TD CLASS="quote">cam?? JUN Type 3 with valve spring and retainer(http://www.junauto.co.jp)</TD></TR></TABLE>
mmmmm......
mmmmm......
the syncromesh(stock) is almost new. used for few hundred kilometres only. can it be the culprit? it looks perfect. can it be the clucth?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir_acap »</TD></TR><TR><TD CLASS="quote">the syncromesh(stock) is almost new. used for few hundred kilometres only. can it be the culprit? it looks perfect. can it be the clucth?</TD></TR></TABLE>
you are referring to syncromesh the fluid correct (as in GM Syncromesh)? (wasn't sure what you meant by stock.)
i believe he means the actual syncromesh as in the "syncros" short for syncromesh. It only takes a couple bad shifts to screwem up.
I would try gm syncromesh and see if it helps any.
Doublejz where are u located i am from greensburg pa.
do you hear any funny noises(clunking), coming from the tranny? i would have to say, that your pressure plate is broken. remove the starter, have a friend turn the engine over. as he does that, use a flash light and check to see if the ribets(straps) that hold the pressure plate together are not busted. also check to see that these straps have moved, if the moved the pressure plate will have too much play in it! this has happened to me more than i care to comment, one misshift and you'll have a good chance of breaking those straps
My GSR is the same way, it is so hard to get into 2nd gear at high rpms i always have to shift real slow. how do i get the syncros fixed?
fixing your syncros is going to cost you an arm and a leg. my syncros were bad as well, it was 5th gear, and i changed my transmission fluid and it helped after a while, i kept on double clutching, first it grinded over 2000 rpm, than 4, than 6, than later after a while it stop grinding at high rpm......than couple more months later my tranny locked up some how, said lik 4 of my syncros burnt or watever, now i got a brand new itr tranny
JDMflavor_EJ
Jul 12, 2004 09:07 PM
