Clutch Problem PLz help (ceramic) 4 paddle
Old May 22, 2004 | 08:55 PM
miketurbohonda's Avatar
Default Clutch Problem PLz help (ceramic) 4 paddle
hey this is what happened when i tightened clutch cover onto fly wheel the fins started to move in (as o clutch is engaging) moved in about 1/4" max is this a problem????? help
thnkas
Old May 22, 2004 | 08:59 PM
EL Vap133's Avatar
Default Re: Clutch Problem PLz help (ceramic) 4 paddle (miketurbohonda)
Nope, that's normal.
Old May 22, 2004 | 09:05 PM
Malgerus's Avatar
Default Re: Clutch Problem PLz help (EL Vap133)
Normal. As you torque it on this will happen. Just be sure to torque it in a star pattern, in increments of 5 ft lbs or so (B series? 19 ft lb should be the final setting).
Old May 22, 2004 | 09:33 PM
Default Re: Clutch Problem PLz help (Mr. S)
thank goodness thanks guys i was worried as i've already put it all back together except axles
thnaks heaps
Old May 22, 2004 | 09:38 PM
EL Vap133's Avatar
Default Re: Clutch Problem PLz help (miketurbohonda)
Good luck on the rest of the swap.
4runner
11
Apr 27, 2006 12:13 AM
TheTealHatch
Apr 1, 2006 02:13 PM
taytay333
Nov 21, 2001 12:58 PM
