how much oil did you car burn?
Old Nov 8, 2001 | 09:05 AM
citanest's Avatar
New User
Default how much oil did you car burn?
Although it's normal, but kind of annoying to add oil every week.
How much oil do you cars burn? Anyway that might help to reduce it?
Old Nov 8, 2001 | 09:06 AM
yoshi234's Avatar
I shoot brides
Default Re: how much oil did you car burn? (citanest)
zero
Old Nov 8, 2001 | 09:10 AM
sackdz's Avatar
I burned from the top dipstick hole to the bottom hole in just one track day.
The nicer you drive it, the less oil it burns
Old Nov 8, 2001 | 09:12 AM
typer_801's Avatar
Default Re: how much oil did you car burn? (yoshi234)
1 qt/3K miles is normal for me, but sometimes as much as 1.5qts. Usually don't burn any until about 2K miles after the oil change, then I can't seem to keep oil in the car
To reduce oil consumption....
1. Switch from synthetic to conventional motor oil. It's not a slippery and won't burn as easily (under normal use).
or
2. Go to a higher weight oil (40/50 as opposed to 30). I believe Castrol has a 5W-50 synthetic. You won't make as much hp, but your engine will be better protected.
Old Nov 8, 2001 | 09:29 AM
IntegraT's Avatar
None
Swepco
Old Nov 8, 2001 | 10:00 AM
BlazinITR's Avatar
New User
Default Re: how much oil did you car burn? (sackdz)
So, TRUE!
Old Nov 8, 2001 | 10:08 AM
Darkteg's Avatar
New User
Default Re: how much oil did you car burn? (Blazin ITR)
every 4 nights of redlines, one liter of castrol TXT but it depends on how hard you drive your car and the kind of oil you use. the better the oil, the more it burns.
Old Nov 8, 2001 | 10:11 AM
AdamITR's Avatar
Default Re: how much oil did you car burn? (Darkteg)
Track driven ... pretty much add oil when you add gas policy.
Old Nov 8, 2001 | 10:12 AM
Back in Black's Avatar
Rather OG
none
Old Nov 8, 2001 | 10:47 AM
B18CXr's Avatar
If i keep it under 8K, about .5 quarts per track weekend.
If to redline, 2 quarts per weekend.
Old Nov 8, 2001 | 12:02 PM
DaeDae12's Avatar
Default Re: how much oil did you car burn? (B18CXr)
my car burns like 2 quarts in between oil changes..but its because my valve guides and seals need to be replaced...
Old Nov 8, 2001 | 02:59 PM
KayOs's Avatar
Your valve seals may be gone or going........Piston rings may also be fried...Do a compression test, then leakdown test to pinpoint the exact cause.
Oh yea, and if you are driving in VTEC all day, then expect to shell out for lots of quarts of oil.
Old Nov 8, 2001 | 03:00 PM
Flux's Avatar
Default Re: how much oil did you car burn? (KayOs)
ZERO
Old Nov 8, 2001 | 03:28 PM
Benjamin Tang's Avatar
Default Re: how much oil did you car burn? (Flux)
1.5 quarts between changes. i'm running synthetic and an aem. i've been told i either have blow-by past the rings, or the breather hose from my valve cover to the aem is sucking everything out of the head, judging from the oily mess i have in my manifold and tb
a&j racing is going to jury-rig a catch can to see if it's the latter
Old Nov 8, 2001 | 03:48 PM
TypeR01-424's Avatar
New User
Burned only about a quarter quart between oil changes but only hit VTEC once or twice a week. Last change burned about 3/4 quart with an average of VTEC once a day. Mobil-1 Synthetic 5W-30.
Old Nov 8, 2001 | 04:14 PM
ThePunk's Avatar
Default Re: how much oil did you car burn? (gtc9977)
After 5K miles....(Vtec at least 3 times a day) less than 1 qt. of mobil-1.
Old Nov 8, 2001 | 04:24 PM
Flux's Avatar
...only hit VTEC once or twice a week,
You are going to need to take your R to a car psychologist to get treated for depression and possible schizophrenia - it may think it is an Accord...
vinuneuro
Mar 15, 2005 04:41 PM
ironballz
May 13, 2004 02:38 PM
blkbeast
May 28, 2003 10:48 PM
NewR
Apr 28, 2002 06:25 PM
TypeR01-424
Aug 17, 2001 07:51 AM
