15.871 Stock Si, Good or Bad time??
Old May 22, 2004 | 07:30 PM
tomu06's Avatar
Default 15.871 Stock Si, Good or Bad time??
I ran my 99 Si stock, only mods are cold-air Aem intake, and tein SS suspension, i had dummies in the front running like 25 psi, it was a hott day. Just wanna know if thats respectable or discusting
Old May 22, 2004 | 07:50 PM
AGS's Avatar
AGS
Default Re: 15.871 Stock Si, Good or Bad time?? (tomu06)
dont think its great but, its not terrible. Maybe a couple tenths quicker??? Its all about the start...traction is KEY.
Old May 22, 2004 | 08:07 PM
tomu06's Avatar
Default Re: 15.871 Stock Si, Good or Bad time?? (1999silverhatch)
Yah, traction wasn't a problem i hooked up pretty good, first time at track though , i need to practice my launch, i'm not really sure what rpm to launch at, kind of testing it out. I'm saving my money to build up engine for turbo. Anyone know what i should do first, pistons *heard LS are best for turbo* , cam gears ect.
Old May 22, 2004 | 08:18 PM
degooser's Avatar
what was your 60 ft? im guessing by the times a 2.4 or 2.3?
Old May 22, 2004 | 08:35 PM
tomu06's Avatar
Default Re: 15.871 Stock Si, Good or Bad time?? (degooser)
60 fts times were 2.466, 2.447, and 2.468
Old May 22, 2004 | 08:37 PM
vtecb20coupe's Avatar
B A N N E D
i would say it's a normal time for a first timer. once you get used to the car and practice your launching, the times will gradually get better. just takes practice and patience.
Old May 22, 2004 | 08:42 PM
tomu06's Avatar
here is time slip
R/T ... .212
60 ... 2.466
330 ... 6.793
1/8 ... 10.313
MPH ... 69.96
1000 ... 13.316
1/4 ... 15.871
MPH ... 88.98
when it came down to Dialing in i dialed in at 15.9 and ran a 15.922, but they fucked up and put me at 15.09 and i still almost beat a 14 second supra
that time slip was
Dial 15.09 *should have been 15.9*
R/T ... .584
60 ... 2.447
330 ... 6.794
1/8 ... 10.334
MPH ... 69.48
1000 ... 13.359
1/4 ... 15.922
MPH ... 88.58
the supra dialed in at 14.00 and ran a 14.802 and i had better R/T his was .601 SO GAYYY oh well i'll look at my Dial in at the end of track next time
Old May 22, 2004 | 10:35 PM
Stones's Avatar
work on your 60' ft. try to get it down to a 2.2
i have a 92 si with d16z6 and i'm hitting 15.8 with a 2.2 60 ft. with your 86mph trap speed your should be well in the mid to low 15's with a 2.2 60ft'
Old May 22, 2004 | 10:45 PM
antiJDM's Avatar
Default Re: 15.871 Stock Si, Good or Bad time?? (EnjOi vtec)
89 mph is good for a 15 or 15.1, its all in the launch, find a street that you can just practice on launch at like 4500 and then adjust accordingly, wheel spin isnt necesarily bad, just dont shift until you get traction (or close)
its a good time tho, i've raced against si's running in the mid 16s with i/h/e IMO it has a lot to do with the driver
Old May 22, 2004 | 10:55 PM
hatchling37's Avatar
Default Re: 15.871 Stock Si, Good or Bad time?? (2thousandcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic &raquo;</TD></TR><TR><TD CLASS="quote">its a good time tho, i've raced against si's running in the mid 16s with i/h/e IMO it has a lot to do with the driver</TD></TR></TABLE>
not too bad, on a new '00 Si, my friend hit a 15.3 with only an AEM CAI, but he's a pretty good driver
i ran in that same car with a toast clutch, heavy 17's and a full stereo and hit a 15.8, so i can't say it's a bad time since i've not done better
practice makes perfect, just get in some track time
Old May 23, 2004 | 12:03 AM
allmotorEG-SI's Avatar
ha i thought you were talking about the older Si's. I just bought my second 94 si. I was thinking, 15 sec 1/4 mile... hot damn this car is faster then I thoght. I guess I was wrong.
Old May 23, 2004 | 01:29 AM
crsn4dr's Avatar
not bad.
Old May 23, 2004 | 06:45 AM
JDM PRO's Avatar
i ran a bone stock Si for the first time w/ 15.9 and i rarely race at the track.
Old May 23, 2004 | 06:48 AM
BlownVR's Avatar
Default Re: 15.871 Stock Si, Good or Bad time?? (JDM PRO)
You could pull of a 15.4 with that setup, get some good tires and run some good times!
Old May 23, 2004 | 11:53 AM
thatboyrob's Avatar
15.8 is about the norm for the first time at the track in a SI. I remember back when they first came out all these people were running 15.6-15.8s, some ppl would pull like 15.4s so ya, thats about right. My buddy got 15.3 in a stock GSR, so do the comparison.
Old May 23, 2004 | 12:38 PM
Dacalac's Avatar
Default Re: (thatboyrob)
according to car & driver the stock 1/4 time for an SI is 15.7. Considering that is your first time at the track you're doin ok.
Old May 23, 2004 | 02:46 PM
tomu06's Avatar
Default Re: (Dirk Lance)
yah i'm going back next month, but i'm gonna try to get an exhaust by then, not getting header because i'm getting turbo down the road.
Old May 23, 2004 | 03:39 PM
JforJonathan's Avatar
Default Re: (tomu06)
pretty good time in my opinion. i could only get 16.0 in my si.
Old May 23, 2004 | 04:24 PM
Synergy001's Avatar
it also depends on the location of the track. when i lived in hawaii and then moved to texas, my times dropped by 0.5 seconds. i couldn't believe it when i seen it. nothing was changed in my car and my driving was still the same.
Old May 23, 2004 | 04:31 PM
Snoopy1's Avatar
Default Re: (Synergy001)
yea, that's not too bad of times.
And you shouldn't feel bad, cause I could only pull a 15.811 @ 90.5mph out of my 92 hatch with a JDM B16a. That's at Firebird in Boise, Idaho, and it was only my second time at the track, so I think we both just need more practice and our times will improve.
good luck
Old May 23, 2004 | 04:40 PM
Uncle Ben's Avatar
Default Re: (Snoopy1)
For only an intake, that's not that bad IMO. I was only able to yank a 16.2 with I/E in the '93...
Old May 23, 2004 | 05:55 PM
Tee Jay's Avatar
Default Re: (Uncle Ben)
WOW I got a 10.122 in my 93' Prelude Si w/ axle back exhaust for the 1/8th
Old May 23, 2004 | 09:16 PM
tomu06's Avatar
Default Re: (Green_Machine)
yah but what was u're 1/4?
i'm sure u're launch was obviously better. thanx for the encouragement
Old May 24, 2004 | 09:21 AM
funky_cornbread's Avatar
not bad at all. similar to my times which was 15.6-15.7 at 89-90mph when i was at that stage. if your going turbo then i would suggest motor mount inserts and possibly wrapping the intake with heat reflective material, a set of sticky tires and make suspension adjustments for drag racing since you have the capability to with the teins. the motor mounts will help aleviate wheel hop and get you out of the hole faster. i played with around 5k and letting it slip out, 500k of wheel hop but when it catches i'm right there at the vtec engagement point.
good luck.
deepsouthhybrid
Honda Civic (2006 - 2015)
138
Jan 14, 2016 05:40 PM
racin jasin R
Mar 31, 2008 10:50 PM
philipwight
May 17, 2005 05:40 PM
si foo
31
May 19, 2004 05:01 AM
Unsung
May 12, 2002 04:17 AM
