trap speed is too low in the quarter mile !!!
Old May 22, 2004 | 06:06 PM
danny98r's Avatar
Default trap speed is too low in the quarter mile !!!
i was at englishtown last night and my best run was a 14.45 @ 95.06mph with a 2.25 60ft. my best time ever is a 14.23 @ 95.78 with a 2.20 60 ft. my mods are an aem cai, jdm headers , jdm cat, and a tanabe exhaust. i see other type r's with the same mods trapping out at 97,98,99 mph. previous to my run at englishtown my check engine light came on and the comp said that i bank 1 was running too rich. could this be the problem to my low trap speeds. and no my bumper is not black. how do i tune this without getting a vafc.. would a dyno with a wideband o2 solve the problem.
Old May 22, 2004 | 07:11 PM
RTW DC2R's Avatar
mess around with your shifting points, just make sure you stay on the big lobe when hitting the next gear. FWIW, so far my best ET didnt have my best trap speed. as far as the problem goes Id start by checking your plugs. not really any way to tune that without some kind of device.
Old May 22, 2004 | 07:27 PM
ultimatehonda's Avatar
Default Re: trap speed is too low in the quarter mile !!! (danny98r)
Thats pretty good 60fts and ET for just a bolt on R....what kind of tires you have?
Old May 22, 2004 | 09:53 PM
98cwitr's Avatar
Default Re: trap speed is too low in the quarter mile !!! (ultimatehonda)
damn i wish i could get 60's like that...im trapping 97s though. BTW you only have 1 header
Old May 22, 2004 | 10:56 PM
itr1244's Avatar
Default Re: trap speed is too low in the quarter mile !!! (98cwitr)
i dont remember exact numbers but i had like 14.7~8 and 97 PMH that's werid..and my best time was 14.6 @ 95~6...
Old May 22, 2004 | 11:02 PM
98cwitr's Avatar
Default Re: trap speed is too low in the quarter mile !!! (itr1244)
^damn your 60' must have been in the 2.6s My 60's arent nothing to brag about...my fastest time was a 14.388@96.80 w/ a 2.35 60
Old May 23, 2004 | 06:31 AM
danny98r's Avatar
i was running on rota slipstreams on falken azenis @ 22psi. i know im not gaining enough on the top end. my plugs have 2 thousand miles on them and they are stock plugs. i checked them and they were burning just fine. im shifing at redline 8400, 8500 rpms. my oil is fine my compression is at 250 across the board. so i dunno, but my check engine light came on.
Old May 23, 2004 | 09:42 AM
MissMyHonda's Avatar
Your 60fts suck...2.1 - 2.05s shouldn't be too hard w/ a bolt on R and a decent street tire, try doing a large burnout first, drop some tire pressure, lauch higher...and your trap will increase as the 60 goes down (until about 1.8 then it will decrease)
You're probibly not shifting fast enough either, you should be "kicking" the clutch and your right arm should be pulling the shifter into gear as the clutch is being depressed, you dont' need the clutch in to pull it out of gear...
You can't tune your car w/o a tuning device, at least get a FPR then jump on a dyno with a wideband, but you wont be able to exact tune the RPM scale just tune 1 section and make sure all other points are safe. Spend the hundred or so $ and get a used VAFC
Old May 23, 2004 | 11:32 AM
Default Re: (JoesTypeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoesTypeS &raquo;</TD></TR><TR><TD CLASS="quote">Your 60fts suck...2.1 - 2.05s shouldn't be too hard w/ a bolt on R and a decent street tire, try doing a large burnout first, drop some tire pressure, lauch higher...and your trap will increase as the 60 goes down (until about 1.8 then it will decrease)
I think his 60ft was pretty good..getting it to the 2.1 is pretty damm hard on street tires...he would need to get slicks to be in the 1.8's....also how much lower can he go on the psi on those falkens? 22 is pretty low for a stiff side wall tire like that.
AllMotor12s
Jul 17, 2006 12:46 PM
servion
Oct 28, 2004 09:19 AM
youngvedder
Apr 12, 2004 11:49 AM
geminis2k
Aug 11, 2003 12:40 PM
1 2 NV
Jun 20, 2002 03:09 PM
