Do you think krylon fusion will work as a flex additive?
Anyone in here use that krylon fusion as a flex additive? I just picked up a lip that needs to be painted and I need to paint it. I saw that commercial where it said it bonded to plastic, just wanted to know how well it worked. If not can someone suggest a good flex additive? Thx
thx! thats all I needed to hear, I almost fell for the hype, any idea on a good flex additive for a primer? I read on here when I searched that if you get paint from paintscratch.com it comes pre-mixed with flex additive, but it didnt say anything about the primer. Let me know what you guys think.
well if your getting black the rustoleom vinyl paint works good on plastic. because it actually forms a thin black almost rubberlike layer, gotta spray it on not to thick tho cause if it gets too thick you can actually scratch it with your nail and peel it off..
and heres some good advice.. never mix this **** with any othe rpaint.. even after its dry.. i dont know what chemical is in it. but it doesnt mix with anything else ive tried to use with it...
i had a whole door panel done dry for like 2 days and i had 1 tinyyy little spot i needed to spray some on, and i used a diff brand vinyl paint. did a little spot.. and the spot turned grey.. which was the original color.. itslike they both combined turn invisable. even with spray paint.. its ******* crazy..
JonnySBeee...
Jun 23, 2005 07:35 PM
