can i do a jdm 5 lug swap w/ d series motor.
i have everything needed to do the swap, axels 36mm, springs/shocks, knuckles, lca's, etc.... I was under the impression that this conversion was just like ur basic usdm 5 lug but now i am hearing that i cant do the conversion since i have a D series motor and because the D series and B series axles are not interchangeble let alone 32mm to 36mm? Is this true and if so is there anything i can do to make them fit?
thanks eric
thanks eric
yes you can swap the five lug and have a d series you either need the usdm type r five lug conv or the jdm type r civic conv. i know it can be done because that is what is on our civic. hope this helps .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n2trble111 »</TD></TR><TR><TD CLASS="quote">yes you can swap the five lug and have a d series you either need the usdm type r five lug conv or the jdm type r civic conv. i know it can be done because that is what is on our civic. hope this helps .
Yea, you could probably put USDM or CTR ones outer joint on the D axle, but the JDM one is a no go.
You can do a 5 lug conversion with a D-Series if you have the conversion from a CTR and USDM ITR because they have 32 mm hubs. The JDM ITR 5 lugs have the 36 mm hubs. You would need 36 mm axles in order to use the JDM ITR 5 lug conversion (if you have a B-Series). If you have a B-Series engine, you can swap your axles to 36 mm JDM ITR axles, but if you have a D-Series engine, you can't because Honda never made any D-Series cars w/ 36 mm axles. You may be able to replace the hubs w/ USDM ITR hubs, but I'm not 100% sure. Or you can sell you JDM ITR set and find a CTR or USDM ITR set. I have the 5 lug brakes from a USDM ITR as well as a D-Series engine and it bolts up perfectly. Oh, and if you're getting 5-lugs w/ a D-Series, I would recommend lightweight 15" wheels (like Volk, Spoon, etc) to compensate for the added rotating mass from this setup. I know that will be my next upgrade.
SoCal EJ1
Jan 30, 2006 12:30 AM
JDM4DRLX
13
Mar 6, 2004 06:28 AM
SPOONfdEK
17
May 25, 2003 04:35 PM
